More electrical help!!!
Discussion in 'The BS Topic' started by bfmgoalie, Jan 14, 2021.
  1. bfmgoalie
    bfmgoalie Veteran Member
    2,754
    1,179
    Jun 14, 2008
    Gansevoort, New York
    Had a remote fan hooked up to the ceiling. It was attached to a black, white, red and ground wire. I want to replace it with a chandelier. The chandelier was wired to the black, white and ground. The chandelier operates with a wall switch. Can I just put a plastic cap and black tape on the red wire to isolate it? Is that safe?
  2. Rusty Shackleford
    Rusty Shackleford New Member
    14
    9
    Jan 26, 2019
    Greenville, NC
    That should be fine.
  3. 73 Z
    1,159
    73
    Jun 9, 2007
    Los Angeles, Ca
    The red is usually means that circuit has 2 or more switch locations, But yeah as said just put a wire nut on it.
  4. Phil G
    Phil G Veteran Member
    895
    121
    May 3, 2004
    Tucker, GA, USA
    ^This^
    Just replacing some switches in my house. The red wire on the switch is for two locations. Instructions state for single location to wire nut the red wire. Even came with the wire nut(s).
  5. Canadian Barton
    Canadian Barton Veteran Member
    344
    140
    Jul 20, 2015
    Alberta
    In the case of a fan the red wire would not indicate a second switch. Fans typically operate with a hot to the light and a separate hot to the fan motor. Cap it off but do so at both ends.
