Moroso TH350 Pan Gasket Woes. Can't Make it Stop Leaking!
Discussion in 'Transmission & Driveline Topics' started by slayer021175666, Feb 2, 2021.
  1. slayer021175666
    slayer021175666 Veteran Member
    1,320
    80
    Feb 29, 2016
    Idaho
    I've mentioned before that my tranny pan leaks. Seems I've tried everything to no avail. I had the stock pan on it and it leaked. Tried cork. Tried rubber. Nothing gained. Still leaked. I thought I'd throw some money at it and get serious so, I bought an aluminum pan and a $35 gasket from Moroso. Big thick blue one with rubber molded around a steel core. No Dice! Leaking worse than ever! I've heard of sanding the gasket surface of chrome pans. Would that work on the aluminum pan? I just don't know what to do. I'm thinking about omitting the gasket and gluing the pan on with grey RTV. What a shame to do it that way, though. I'm sure it would stop the leak but, It'd be a MAJOR PITA when I need to pull the pan off later. I've never had so many fits in my life getting one to seal. Hoping you guys have some guru knowledge for me. I'm also open to a miracle, potions, chants, dances and anything else short of, selling my soul. I'm still using it, right now.
  2. Zspoiler
    Zspoiler Veteran Member
    4,158
    501
    May 6, 2012
    Federal Way, Washington
    Make sure the surfaces aren`t warped first .The thick FeLpro gaskets with blue "RTV " mostly works as well.
  3. camaro71/holland
    1,552
    214
    Aug 27, 2003
    The Netherlands
    When you've tried several different pans with no luck, then the problem might be the case flange itself. Try to straighten the flange with a long (fine tooth) file. The case needs to be empty of course and cleaned thoroughly afterwards.
    budro6968 likes this.
  4. Chevyforever
    Chevyforever Veteran Member
    1,230
    591
    Jan 4, 2011
    Is there any chance you have too much fluid in trans ?
  5. Coadster32
    2,311
    372
    Oct 2, 2013
    Milford,CT
    I had a same issue going back a few years now with a TH400 tranny pan. I tired Moroso gasket, cork, rubber, rtv...and the darn thing kept leaking. I sealed up the speedo gear housing, and the vacuum modulator as well. Come to find out, there was a crack in the dipstick tube that was seeping the fluid.
    sandlapper likes this.
  6. John Wright
    15,290
    431
    Aug 9, 2002
    Rustburg, Va
    It's hard to believe that didn't seal, those will seal on a warped or rough surface. Can you clean everything really good with brake kleen or carb cleaner, get it really dry, then start dusting it with flour and see if you can find where it is seeping out before it turns into a drip and runs...
  7. COPO
    21,353
    2,781
    I would smear a small layer of RTV on both side of the gasket.
  8. budro6968
    budro6968 Veteran Member
    4,081
    823
    Apr 2, 2016
    Jax Florida
    I would check the case flange with a straight edge. Make sure it is flat. Has the trans ever been in a wrecked car? Could have a hairline crack.
  9. sandlapper
    sandlapper Veteran Member
    984
    395
    Oct 9, 2020
    SE CSA
    how about checking the new Cast pan's rails on a surface plate or pane of glass; may be new Casting but warped as well. If so; pounding on it's rails (like a stamping) ain't gonna help.
  10. GoldenOne7710
    5,637
    903
    Jun 23, 2004
    Athens, GA
    Might look for other issues than the pan gasket leaking, too. Leak could be coming from somewhere else. What area of the pan is wet?
    Knuckle Dragger likes this.
