Moth balling a rear end
Discussion in 'Transmission & Driveline Topics' started by Mojo925, Nov 8, 2013.
  1. Mojo925
    Mojo925 Veteran Member
    198
    Jul 4, 2012
    Antioch CA
    So since I picked up my 4.10 Posi rear Ive been trying to decide what to do with my old one. I've decided to keep it but i haven't been able to find out how to Moth ball it for long term storage.
    I plan to wrap it in Plastic ( Industrial shrink wrap like the kind used for wrapping pallets) and cover it in a tarp. My biggest concerns are the fluid and making sure it doesn't seize up or anything of the link.
    Should I drain it or keep the fluid?
    is there an additive i should use to make sure it stays usable?
    any recommendations are appreciated.
  2. big gear head
    big gear head Veteran Member
    6,398
    172
    Jul 30, 2001
    Central City, Ky.
    Anything above the oil level, gears, axles and inside of the housing, will rust after time. Don't drain it. It would be a good idea to turn the pinion several times at least once a year to coat the gears with oil. If you keep it inside and keep the temperature consistant all year then it should be all right.
    Had to edit this. I had below instead of above.
  3. Kamikaze
    5,038
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    If you can find some "Fogging" oil, you can remove the fill plug on the side and spray in inside to coat the gears and carrier. Like posted above, turn it a few times a year to help prevent seizing up and dont drain the lube.
  4. Bumpad_Z28
    Bumpad_Z28 Veteran Member
    500
    Apr 9, 2004
    Logan, UT
    I dunno about the shrink wrap ... Holds moisture in ?
  5. prosuperstar5
    prosuperstar5 Veteran Member
    292
    Apr 2, 2010
    Savannah Georgia
    What was the 4.10 posi rear from? Aftermarket? I'm looking for that same gear.
  6. BonzoHansen
    20,673
    1,761
    Jun 1, 2005
    Scott from Hamilton, NJ
    +1 I lost a set of 3.90 gears because I neglected it and the gears pitted where they were not in the gear oil
  7. Mojo925
    198
    Jul 4, 2012
    Antioch CA
    The 4.10 posi was from a 72 camaro, and aftermarket. ( 10 bolt but its not likely to blow from the minuscule HP im making ). Craigslist find for $300
    I was hoping the shrink wrap and a little bit of silicone around the diff cover would keep rain out. I wanted to store it in the shed in the back in hopes it would stay dry enough.
    So keep it full, turn it a few times a year and fogging oil should keep it happy?
  8. troutman
    troutman Veteran Member
    121
    Mar 16, 2009
    Chapin,S.C.
    Also turning it often will help keep seals from leaking.
  9. Mojo925
    198
    Jul 4, 2012
    Antioch CA
    good to know! thank you guys for all the help
