Motor mount replacement
Discussion in 'Engine Topic' started by Mr Sunshine, Apr 6, 2021.
Is this the correct direction?
Poll closed Apr 13, 2021.
  1. Correct
    100.0%
  2. Not correct
    0 vote(s)
    0.0%
  1. Mr Sunshine
    Mr Sunshine Veteran Member
    129
    17
    Dec 12, 2016
    Missouri
    I have reconditioned my clam shell plates for my 78 Z28 and putting in the Energy Suspension poly mounts.
    The directions supplied are not very clear which way these go. I think I have it correct, but would like other opinions to validate since I don't want to take these back off after I have reassembled my new front suspension components. Take a look at the photos and let me know if this is the correct way they go.
    Thanks,
  2. Jodi
    Jodi Veteran Member
    809
    522
    May 22, 2019
    The two metal tabs protruding on both sides, one is wider than the other... The wider one should be towards/near the clamshell mounting holes that are farther apart from each other. So it looks like you have it the correct way.
    Don't forget the ty-wrap ;)...
    Mr Sunshine likes this.
  3. biker
    biker Veteran Member
    3,461
    1,546
    Dec 7, 2014
    Looks correct to me, same as I did with mine. I just looked under my hood. Attached a couple pics of the drvers side. Not great, but shows the wide tab towards the top. 20210407_090708.jpg 20210407_090635.jpg
  4. Twisted_Metal
    29,505
    2,394
    I found it easier to install the frame side mounts with bolts pulled up through the frame with wire or fishing line.
    I hit the nuts with an impact wrench and didn’t have to hold the bolts inside the frame to get them tight.
    Makes the job much quicker.
  5. biker
    3,461
    1,546
    Dec 7, 2014
    Damn. Where were you when I did mine?
  6. Twisted_Metal
    29,505
    2,394
    I picked up the idea from someone on NastyZ over a decade ago.
    When I swapped engines,
    I bought the wrong mounts the first time and had to install them TWICE :mad:
    Thankfully, I had mounted them “nuts up” and it only took half an hour to replace them with the correct ones.
  7. Mr Sunshine
    129
    17
    Dec 12, 2016
    Missouri
    Thanks for the replies, it helps to get experienced feedback!
