MSD Install Parts
Discussion in 'Engine Topic' started by RS1979, Jan 22, 2014.
  1. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Swap Meet section, ebay, craigslist
  2. RS1979
    4,055
    965
    Jun 18, 2013
    Memphis, TN
    I just got off the phone with MSD. They told me the 6AL will work with my Mallory and the spiral core wires. He said to not use the solid wire core wires; but, their spiral core wires would be fine. I hope he's right.
  3. troutman
    troutman Veteran Member
    121
    Mar 16, 2009
    Chapin,S.C.
    Power resistor.
  4. RS1979
    4,055
    965
    Jun 18, 2013
    Memphis, TN
    When you say power resistor do you mean ballast resistor or do you mean a Mallory will restrict the power from a MSD?
  5. lumpy12
    lumpy12 Veteran Member Lifetime Gold Member
    727
    16
    Sep 16, 2012
    NorCal
    I got these 'cause I had to .... [​IMG]
    http://www.summitracing.com/parts/pow-pow301150/overview/
    A couple of my plugs are impossible w/out these
  6. RS1979
    4,055
    965
    Jun 18, 2013
    Memphis, TN
    Thanks, I'll look into it. I'd still rather have a set of headers that would make it easier. There's probably not a long tube set made this way.
  7. troutman
    121
    Mar 16, 2009
    Chapin,S.C.
    Sorry, i meant a ballast resistor. Learned to use one after burning out centers of two dist. caps because missing a resistor.
  8. RS1979
    4,055
    965
    Jun 18, 2013
    Memphis, TN
    No problem. I've never used a MSD 6AL before and I want to be sure I don't screw up my ignition system.
  9. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    The Mallory will still burn out with na Mallory ballast resister and coil.I got 10 passes on it.
    I have over 1,000 passes on the MSD 85551, Blaster II and 6al without a missed beat.
  10. RS1979
    4,055
    965
    Jun 18, 2013
    Memphis, TN
    Screw what the guy at MSD said. If both hhott71 and K5JMP say go with a Pro Billet, I'll do it. I'd rather be sure than wonder every time I go out in the car if I'll make back home.
    Thanks guys.
