muncie side plate question
Discussion in 'Transmission & Driveline Topics' started by 70454inutah, Sep 5, 2020.
  1. 70454inutah
    70454inutah Member
    39
    Sep 10, 2014
    provo utah
    Ive got a 67 chevelle m20 in my 70. what all would have to change out to use the 3/8s bolts for shifter lever arm attatchment. 67 uses the weaker studs plus all my levers are for bolts. didnt know if i have to change the entire side plate assembly with forks or just parts of it.
  2. tom3
    tom3 Veteran Member
    13,040
    799
    Aug 1, 1999
    ohio
    I'm scratching my head on this one, are the levers actually different?
  3. McCune
    McCune Veteran Member
    1,225
    270
    Aug 22, 2015
    st.george utah
    I think you are talking about these shift shafts? muncie shift shaft late model.jpg
  4. 70454inutah
    70454inutah Member
    39
    Sep 10, 2014
    provo utah
    So you had levers that had 5/16 stud. Then 3/8 stud and then 3/8 bolt. Pretty sure all the poo forks are the same. That leaves the question of do the parts mccune show. Have to match the side plate I believe
  5. McCune
    1,225
    270
    Aug 22, 2015
    st.george utah
    Side cover are the same,I believe. I have a guy that has the parts you need and he is in St George.
  6. 70454inutah
    70454inutah Member
    39
    Sep 10, 2014
    provo utah
    Right... I believe. Those are what either contain the studs or bolts, but do they have to match the same side plate and forks. Although I believe all the forks are the same
  7. McCune
    1,225
    270
    Aug 22, 2015
    st.george utah
    You can take out the stud levers and replace them with bolt levers. Nothing else changes.
  8. 70454inutah
    70454inutah Member
    39
    Sep 10, 2014
    provo utah
    Seems like I had read some where the depth was different on one of the set ups though I don't recall exactly which one. Also I'd be curious what he has and what he wants for them
  9. 70454inutah
    70454inutah Member
    39
    Sep 10, 2014
    provo utah
    That's what I wanted to know. I didnt want to have to change the entire assembly
  10. McCune
    1,225
    270
    Aug 22, 2015
    st.george utah
    My guy can tell you anything about what you are asking. I'll talk to him tomorrow.
