My '81 Camaro from Indiana!
Discussion in 'Project Progress' started by Eighty1Camaro, Apr 29, 2013.
  1. Eighty1Camaro
    Eighty1Camaro Veteran Member
    619
    Apr 28, 2013
    south central Indiana
    Something I have just been working on is the Shifter as it needs adapted for the OD Trans thats now in the car. So I went with the Shiftworks kit. I *may* have to change out the selector on the trans but I need to inspect it first.
    A little custom color on the Indicator:
    Johnny Blaze likes this.
  2. Eighty1Camaro
    619
    Apr 28, 2013
    I also did get the LS6 intake on, it came with the rail on it. I tested the injectors. 2 were bad, so I replaced them, and got a rebuild kit for the other 6. Had to bend the inlet part a bit to clear coil pack. Just have to run a line from the firewall area to it and my fuel system will be sealed up.
  3. Bandit723
    Bandit723 Veteran Member
    3,331
    503
    Oct 1, 2016
    Waupaca WI
    The ShiftWorks Kits work pretty well - Like the color add to the gear indicator.
  4. 80sz
    80sz Veteran Member
    3,430
    510
    Feb 2, 2014
    Buffalo,n.y.
    Yup the shifter color cool. Nice
  5. Eighty1Camaro
    619
    Apr 28, 2013
    Finished up the Power Steering system today. Like I previously stated I used a mid 9-s Grand Cherokee box, and I added an 03 Silverado HP line, and return line from Cherokee
  6. Eighty1Camaro
    619
    Apr 28, 2013
    I ordered a Griffin Radiator (PN#8-70010-LS) and Derale Fan package (PN#16826 ) and I went about installing what I could today. I was able to use the replacement Radiator bushings with a little clearance along bottom of the rad support to avoid metal/metal contact and some clearance along the edge of the top plate to it could clamp the radiator down properly.
    The steering gear box is in the area where the fan shroud would be so I made a careful measure and cut of this area (below)
    I need to finish up with some lower brackets, and all that then hose and line it up..etc.
  7. 8pack
    2,686
    167
    Aug 29, 2007
    Western, MA
    The sticker is on crooked!! Looks good. Interested to see how that set up works.
  8. Eighty1Camaro
    619
    Apr 28, 2013
    Yes I know, I noticed that when i pulled it out of the box, I'll probably remove it and stick in on the toolbox anyways.
  9. Eighty1Camaro
    619
    Apr 28, 2013
    I had to bottom mount the fan shroud so I came up with some brackets and installed them. Also some hoses. They fit great!
  10. Johnny Blaze
    Johnny Blaze Veteran Member
    930
    27
    Jan 24, 2013
    New Washington, IN
    Looking good!
