Lars_2Gen
Awesome, thanks!
Does the window sweep clear the drip rail when you close the door?
The tip of the rubber on the sweep (driver's side only) gets caught on the drip rail.
I've never bothered to try adjust it.
It doesn't cause wind noise or leak water inside so it's just little quirk I've learned to live with.
metal lock nuts ,spray silicone where it goes through bushing. jegs and summit have small tub of silicone grease definitely wear disposable gloves when using and try not to get on anywhere but where you want it lol.I don’t want to pee on your parade but if you really cranked down on the nuts on the spring shackles you are going to have significant binding and a harsh ride. You don’t want those nuts that tight.
I can’t tell what kind of nut you used but the best solution is to use a “top nut” which is all steel and can’t back off. Tighten the nut until you have just taken the slop out so the shackle are snug, but not tight against the bushing.
Even though the car has all the weight on it now it still needs to be driven a little bit before the bolts are fully snugged up. It all needs to settle out before the final tightening. Again, if you over tightened them now the suspension won’t be able to settle out when you drive it…..
Those look like poly bushings? If so you want to get some of that sticky silicone lubricant between the shackles and the bushing and it doesn’t hurt to put it in the bushing sleeves as well. Even if they are rubber that is a good idea.
You may want to consider going back over your install. You don’t necessarily have to take it all apart. If you spread open the shackles when you loosen or replace the nuts you can easily get the silicone lube in there with a small acid brush or long flat head screwdriver.
