My Combo...
Discussion in 'High Performance Modifications' started by jemeah, Sep 17, 2010.
  1. jemeah
    jemeah New Member
    26
    Sep 19, 2007
    IstanbuL /Turkey
    -350 sbc goodwrench with standard compression
    -Edelbrock RPM intake
    -650 CFM holley double pump (or 750 cfm)
    -COMP Cams Pro Magnum roller rocker (CCA-1301-16)
    -COMP Cams hydraulic roller lifters (CCA-853-16)
    -Dart Pro 1 355-T6 aluminum cylinder heads 230 CC intake and 64 CC chambers(DRT-11711143P)
    İ wonder is this heads run in my standard block without any problems and What kind of HP?? Thanks...
    74 camaro with TH400 and 3.08 gears
  2. jemeah
    jemeah New Member
    26
    Sep 19, 2007
    IstanbuL /Turkey
    And i have cam with 510 lift but we couldnt find brand or any part number but it looks nice :)
  3. jimbaughan
    jimbaughan Veteran Member
    310
    Sep 1, 2007
    meansville,ga
    Way too much head.
  4. 1BAD78
    1BAD78 Veteran Member Gold Member
    814
    Apr 12, 2007
    Broken Arrow Ok
    yeah way too much head those are for big cubic inch small blocks.
  5. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    dude you need a 170cc to 180 cc head, this head is for high comp and large cubic inch small blocks...
  6. Blown Camaro
    Blown Camaro American by birth, drag racer by choice
    1,199
    140
    Dec 13, 2009
    Deltona, FL
    This combo is going to fall flat on it's face and never pickup until around 4,000 rpm. Then, the cam is going to run out around 6,000rpm. You will need a lot of gear and converter and the car will still be slow.
