RickM
Maybe this will help someone who comes across the same problem I had with my exterior door handle.
I dont know if it is the door handle, the door latch, or the door skin that caused this problem. Probably a combination of all 3 since all are aftermarket parts.
The problem was that I had to pull really hard on the exterior door handle to get the door to open, sometimes I couldnt get it to open at all unless I used the interior door handle. Using the interior door handle the door opens perfectly.
Upon closer inspection it was obvious that the rod that connects the exterior door handle to the latch seemed to be too short, it would not push the latch lever far enough to release the door from the striker. This was happening on both doors. Both had the same aftermarket handles, latches and door skins.
Here is the rod I am talking about
In order to get the rod to push the latch lever down further it needed to be lengthened at the curved section in the center of the rod so I cleaned up that section
And then tacked on about a 1/4 inch of weld
Put the rod back in place and viola! given that the extra length pushes the latch down further the door opens perfectly .
I imagine if you don't have a welder some JB Weld might also work. You could probably put a blob on the striker part instead of the rod.
If your door is hard to open with new/aftermarket parts this may be the answer.
RickM
RickM
