My first 2nd Gen Camaro
Discussion in 'Project Progress' started by Jon Reese, Oct 13, 2021.
  1. G72Zed
    G72Zed Veteran Member
    3,131
    1,583
    Sep 8, 2015
    First off, welcome to NastyZ, secondly, great work on the floors, wiring and interior as well, the insulation is work, but very well worth it.
    It makes it so much better with a supportive spouse, sometimes that's what makes the difference seeing a project getting to the finish line.
    Congrat's, and keep us updated, enjoy the journey.
    Jon Reese likes this.
  2. ls777z
    ls777z Veteran Member
    2,209
    34
    Feb 19, 2000
    Clay,NY
    Anywhere in NY seems to do a job on our cars. Glad to see another member nearby. I'll be looking for you at next summers shows.
  3. Jon Reese
    Jon Reese New Member
    23
    9
    Aug 10, 2020
    Where abouts in NY are you located?
  4. ls777z
    2,209
    34
    Feb 19, 2000
    Clay,NY
    Clay, just north of Syracuse. You?
  5. Jon Reese
    23
    9
    Aug 10, 2020
    New Hartford, just outside of Utica
  6. Ratty_81
    Ratty_81 Veteran Member
    215
    119
    Nov 13, 2020
    Welcome and great job!
  7. Scott51
    Scott51 Veteran Member
    742
    119
    Jan 2, 2012
    New Zealand
    you welded those floor pans in right??
  8. Jon Reese
    23
    9
    Aug 10, 2020
    3M Panel bond. My friend does body repair for a living and that was his suggestion.
  9. Bandit723
    Bandit723 Veteran Member
    3,699
    685
    Oct 1, 2016
    Waupaca WI
    had to google this interesting. Quote from the net:
    I read somewhere that a normal weld has a tensile strength of 1500 psi where the 3m panel bond has a tensile strength of 3,000-4,000 psi. So the Adhesive is plenty strong for the project I am working on Heck, Mercedes, BMW etc has some cars now that are almost completely glued together using this type of adhesive
  10. Jon Reese
    23
    9
    Aug 10, 2020
    It's pretty amazing what this stuff is capable of. Another advantage is that it completely seals as it bonds. We still seam sealed everything inside and out. Welding also naturally creates oxidation during the process. I was skeptical when he first mentioned doing it this way but if it's good enough for McLaren to build their cars with I figured it would be ok for this project.
    Oldskool62 and Bandit723 like this.
