My foam died
Discussion in 'Interior Restoration' started by marauder64ky, May 30, 2008.
  1. marauder64ky
    marauder64ky Veteran Member
    163
    Jan 21, 2005
    Falmouth, KY USA
    Had a nice original 79 Z28 light blue cloth headliner up until this week. Within the past few days it has fallen down. I took it out, and it looks like the foam is still stuck to the board but the cloth has seperated from the foam. Anybody ever have any luck with a spray adhesive? Doesn't seem like it would work to well to me though. I think you would have a problem with the glue showing through the material. NPD sells a kit where you get knew foam and material and use your old board. $53.00 bucks I think. Anyone done this repair or used this kit?
  2. Batman
    Batman Administrator Staff Member Lifetime Gold Member
    8,726
    35
    Dec 13, 1999
    Mission Viejo, CA, USA
    I've done both the foam backed headliner (available at most upholstry shops) as well as now an ultrasuede headliner. Both times I used a wire brush to get rid of the old disintegrating foam, and then used spray adhesive to adhere the new headliner to the cardboard backing. Biggest tip is to let the adhesive sit for a minute before gluing the material to it.
  3. Twisted_Metal
    29,938
    2,707
    ^^^ Good info!
    The foam disintegrates. It's a messy job but it must be removed.
    (If you tried to reglue the cloth to the foam , the glue would soak through the cloth and look like crap.)
  4. 3_z28camaro
    3_z28camaro Veteran Member Lifetime Gold Member
    4,448
    Dec 17, 2004
    Acton, CA
    What I did for my headliner was use a wire brush to clean the cardboard backing then I got some material from a local upholstery shop. To adhere the two surfaces together a thin layer of contact cement was used on each surface. It turned out really well and has held so far after a year. Hopefully it continues to hold.
  5. ineed73parts
    ineed73parts Veteran Member
    224
    Feb 29, 2008
    cocoa pebbles thrown on meh
    you could vacuum the old foam foam off, it works perfectly, with hardly any mess
  6. 73RS
    73RS Veteran Member Gold Member
    249
    Mar 7, 2006
    Gonzales LA
    I just helped my apolstry guy do mine not long ago.
    We pulled the cardboard out by removing the interior peices as needed.
    Then as 3 z28 said used a wire brush to get off the old glue and foam from the cardboard.
    He layed out the liner so that half of it was carefully folded over on the cardboard.
    Sprayed that half, both the liner and the cardboard. He uses a spray gun to spray on the adhesive to both the cardboard and the liner, let it sit until tacky then put it on.
    Then do the other half and your done. worked great and actually pretty easy.
    Remember to work it from the middle on out to avoid wrinkles.
  7. thepostaljester
    thepostaljester Veteran Member
    204
    Apr 23, 2008
    Hanging in the Funhouse full of Evil Clowns
    you need to consider WHY it suddenly fell. Most headliners fail because of excessive moisture in the car from leaks, rust perfereation or a bad heater core. Before you replace the headliner make sure you don't have a water issue first, or you will be replacing it again in a few weeks. Have you noticed any condensation or moisture inside your car reacently?
  8. my24ktrat
    my24ktrat Veteran Member
    1,231
    Jul 5, 2007
    Roch., NY
    I've done both my camaros with that kit , just take out the cardboard headliner, turn it over and use the other side using the spray glue and new cloth , no problems, that way you don't have to scrape notta' , my .02 ,DC
  9. 73RS
    249
    Mar 7, 2006
    Gonzales LA
    Most of the failures I have seen occur because the foam has a certain life to it then it fails. I find garaged cars last a whole lot longer than cars that just sit in the sun alot, the heat kills that foam. Inside temps in a car can get over 140 degrees. I find when the foam has reached come to the end of it's life it just starts to crumble and the liner falls quickly.
  10. marauder64ky
    163
    Jan 21, 2005
    Falmouth, KY USA
    Great info guys. Thanks. And no, nothing has changed in the car or the garage recently, but the weather has turned humid in the past few days. I think it just reached the end of its life. Lasted 29 years. Thats probably longer than most lasted.
