Bought some 15x7 4"BS and 15x10 5.5"BS Vision Wheels from Summit. Fronts have 245/60/15 Mickey Thompsons. Rears are 295/50/15 Mickey Thompsons. Suspension is full Hotchkis coils/leafs, with front and rear sway bars, and KYB shocks. Rear wheels/295s fit fine all I had to do was trim a 1/4" off of the threaded end of the rear shocks as there was only about an 1/8" gap from touching the rim. Edge of the front fender lip is 26.5" to the ground and the rears are 27". No rubbing or interference issues whatsoever in the front or rear!
From this angle, they appear stick out of the wheel well. Do you have a side shot? I will tell you, under a hard bump or hard G turns, clearance shrinks. Just be careful of that as a cut tire can blow and cause you issues.
They are fully tucked and don't stick out. I rolled the fender well lips back in the 90s so there is that added security too.
