N.O.S. & Used Original Parts For Sale - 2021
Discussion in 'Swap Meet Section' started by DCL70, Jan 7, 2021.
  1. DCL70
    DCL70 Veteran Member
    1,688
    59
    May 5, 2007
    The South of N.H.
    For Sale: Used Original Flywheel with casting # "3789733" dated "C 20 0" (March 20, 1970) for 1970 Camaro SS350 models with 4-Speed M.T. and 1970 Camaro models with the 396 engine as well as other Chevrolet models that use a 11" clutch disc.
    The flywheel measures about 1.19" thick. The measurement from the clutch face surface to the surface that bolts on to the crankshaft measures about 1.00". I believe that the flywheel has never been resurfaced as the flywheel edge still has a substantial beveled edge that measures about 0.15" wide.
    This flywheel is used with the bell housing with casting number "3899621".
    The flywheel should be re-surfaced before using. The ring gear has wear on one edge and probably should be replaced or maybe even reversed as the other side of the ring gears does not have any wear.
    The GM part number for this flywheel in my 1970 Chevrolet Parts Catalog is 3889694 in Gr. 0.666 and is listed for 70 All w/4BC (exc. Sp. H/Per., A.T.) and 70 All w/4BC (396,400)(exc. A.T.). as well as other 1965-1969 models. The description is "w/11"coil sprg. clutch (12 5/8" bolt circle) solid type".
    The flywheel itself weighs about 29 lbs. so shipping could be expensive.
    $30 for the 3789733 flywheel plus shipping and Paypal fee (if applicable).
    If interested or if there are any questions, send me a PM.
    Dave
    SOLD
    Flywheel casting # 3789733 dated C 20 0 - 1 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 2 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 3 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 4 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 5 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 6 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 7 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 8 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 9 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 10 of 11.jpg Flywheel casting # 3789733 dated C 20 0 - 11 of 11.jpg
  2. l16pilot
    2,099
    263
    Dec 13, 2004
    Hurlock, MD, USA
    Hi Dave,
    I'll take the flywheel if no one else has claimed. will send you a PM
    badazz81z28 likes this.
  3. DCL70
    1,688
    59
    May 5, 2007
    The South of N.H.
    For Sale: Used Original Front Stabilizer (aka, anti-sway bar) BRACKETS, GM # 406887 as shown in the 1970 Camaro Assembly Manual (UPC 3, Sheet A5).
    Both brackets have an oval stamping with the letter "M" stamped inside the oval.
    GM # 406887 is also listed in my vintage Chevrolet Parts Catalogs in Gr. 7.242 for the following models:
    70-721 Nova, Chevelle, Camaro
    72-75 All
    76-81 ALL
    The bracket shown on top of photo #1 and photo #6 has some mild pitting from surface rust which I removed with my wire wheel. Painting the bracket may fill in most of the mild pitting.
    The bracket on the bottom of photo #1 and photo #5 is in excellent condition without any pitting.
    $30 for the original pair of front stabilizer brackets plus shipping and Paypal fee (if applicable).
    Dave
    Stabilizer FRONT Brackets Original GM  406887 - 1 of 6.jpg Stabilizer FRONT Brackets Original GM  406887 - 2 of 6.jpg Stabilizer FRONT Brackets Original GM  406887 - 3 of 6.jpg Stabilizer FRONT Brackets Original GM  406887 - 4 of 6.jpg Stabilizer FRONT Brackets Original GM  406887 - 5 of 6.jpg Stabilizer FRONT Brackets Original GM  406887 - 6 of 6.jpg
  4. DCL70
    1,688
    59
    May 5, 2007
    The South of N.H.
    For Sale: Original used 1970-1972 Camaro and 1973 Camaro Rally Sport front outer bumper brackets, stamped GM # 3986565 LH" & "RH 3986566".
    No longer for sale
  5. DCL70
    1,688
    59
    May 5, 2007
    The South of N.H.
    For Sale: N.O.S. (New Old Stock) Flywheel to Crankshaft 7/16"-20 X 1" Bolts for manual transmissions, GM # 839756, as listed in my 1970 Chevrolet Parts Catalog (Oct. 1970) in Gr. 0.669.
    The set of 6 bolts each have the "RBW" and the 6 radial line segments (for Grade 8) on the head of each bolt. Included are 6 new after market external star lock washers.
    $12 for the 6 bolts and 6 lock washers plus shipping and Paypal fee (if applicable).
    Dave
    SALE PENDING
    Bolts Flywheel GM 839756 - 1 of 3.jpg Bolts Flywheel GM 839756 - 2 of 3.jpg Bolts Flywheel GM 839756 - 3 of 3.jpg
  6. stafs05
    552
    58
    Dec 26, 2007
    chicago,IL
    Hello Dave I will purchase these. Thank you
  7. stafs05
    552
    58
    Dec 26, 2007
    chicago,IL
    Sorry Dave I did not completely read your details, I have an Auto transmission. Thank you pointed this out to me.
  8. Dave Nelson
    Dave Nelson Veteran Member
    5,533
    5,232
    Dec 19, 2003
    Vineland N.J USA
    Pm sent
  9. DCL70
    1,688
    59
    May 5, 2007
    The South of N.H.
    For Sale: A pair of New (or possibly New Old Stock) grease caps for 1970-1972 Camaro and Firebird models, GM # 3984810, as listed in my 1970, 1971, and 1972 Chevrolet Parts Catalogs in Gr. 6.330. The O.D. measures 2.08" or 2 5/64".
    GM 3 3984810 was replaced by GM # 6274217 in July 1972 as per Chevrolet Parts History.
    Photos #1 and #2 show the new (or possibly N.O.S) grease caps that I bought from a Corvette vendor in Miami about 10 years ago. They are identical to a N.O.S. 3984810 grease cap that Oldsobsolete.com has for $125.
    $20 for the pair of new grease caps as shown in photos #1 and #2 plus shipping and PayPal fee (if applicable). SALE PENDING for the new caps.
    $5 for the pair of original 1970 Firebird "dented" grease caps as shown in photos #3 and #4 plus shipping and PayPal fee (if applicable).
    SALE PENDING for the original "dented" caps.
    Dave
    Grease Caps 3984810 - 1 of 4.jpg Grease Caps 3984810 - 2 of 4.jpg Grease Caps 3984810 - 3 of 4.jpg Grease Caps 3984810 - 4 of 4.jpg
  10. DCL70
    1,688
    59
    May 5, 2007
    The South of N.H.
    For Sale: Used original 1977-1978 Camaro Recess Park and Pulse WIPER SWITCH, GM # 461214, as shown in Gr. 10.163 of the Chevrolet Parts Catalogs.
    SOLD ON EBAY.
