N.O.S. & Used Original Parts For Sale - 2021
DCL70
1,969
The South of N.H.
For Sale: Used Original Flywheel with casting # "3791021" dated "A 7 6" (January 7, 1966) for 1963-1968 Corvettes w/327 engines, 1967-1969 Camaro Z28 w/302 engines, and 1964-1968 All Chevrolet models w/283, 307, and 327 engines with manual transmissions as shown in my vintage Chevrolet Parts Catalog in Gr. 0.666.
The flywheel measures about 1.50" thick. I believe that the flywheel has never been resurfaced but I am not 100% sure. The flywheel edge still has a beveled edge that measures about 0.10" wide. I am not know what the thickness is of a NOS flywheel with casting # 3791021 (GM # 3791022 in Gr. 0.666).
This flywheel is used with the bell housings with casting numbers "3840383" and "3858403".
The flywheel should be re-surfaced before using. The ring gear should also be replaced.
The shipping weight of the flywheel in a 14.5" X 14.5" X 2" box weighs about 31 lbs. Shipping to the East Coast is reasonable but shipping to the West Coast is expensive. Shipping will be via UPS or FedEx and will depend on the zip code of the buyer from my zip code 03054.
$25 for the 3791021 flywheel plus shipping and Paypal fee (if applicable).
If interested or if there are any questions, send me a PM.
Dave
DCL70
1,969
The South of N.H.
For Sale: Slight Used (almost N.O.S.) TIMING COVER (stamped "26") N.O.S. Timing Cover TAB, GM # 3991436, and Used Timing Cover TAB, also GM # 3991436 for 350 w/Sp. H/Per. engines with 8" diameter harmonic balancers.
I bought this service replacement timing cover back in the 80's or 90's from my local Chevrolet dealership and installed it of a rebuilt 350 engine but never started it up because I finally located the "correct" timing cover. The seal, stamped "14033199" and "NATIONAL", is still good because the engine was never started up.
$5 for the service replacement timing cover plus shipping and Paypal fee (if applicable).
N.O.S. GM # 3991436 Timing Cover Pointer as shown in photo #5 (16 degree advance , 8 degree retard) stamped with a small letter "W" inside a larger letter "M".
$15 for the N.O.S. pointer plus shipping and Paypal fee (if applicable).
USED GM # 3991436 Timing Cover Pointer as shown in photo #6 (16 degree advance , 8 degree retard) stamped with the letters "P" & "F".
Dave
DCL70
1,969
The South of N.H.
For Sale: Used TIMING COVER for 8" diameter harmonic balancer. I bought this at swap meet many years ago and believe it might be for 1970's Chevrolet truck. I have never seen this type of timing cover on a Chevrolet car. The cover has a few minor "dings".
$5 for the Timing cover plus shipping and Paypal fee (if applicable).
Dave
DCL70
1,969
The South of N.H.
For Sale: N.O.S. (New Old Stock) AC Delco Speedometer Cable, GM # 88959478 in Gr. 4.342. The cable is still in the sealed AC Delco wrapper. As shown in photo #5 the length of the cable is 77.8" long. The buyer should check to see if this cable is a suitable length for his or her car.
Summit sells this cable for $50.99.
Amazon sells it for $37.94.
$15 for the N.O.S. GM Speedometer Cable plus shipping and Paypal fee (if applicable).
DCL70
1,969
The South of N.H.
For Sale: Used Accelerator Pedal Control Cable Support, GM # 326564, as listed in my 1972 and 1973 Camaro assembly Manuals.
GM # 326564 is listed in my 1972 Camaro Assembly Manual (UPC 6N, Sheet 4) for models with L48 and LS3 options.
GM # 326564 is also listed in my 1973 Camaro Assembly Manual (UPC 6N, Sheet 4) for models with Z28 and L48 options.
According to the REVISION RECORD GM # 326564 replaced GM # 3992376 on 11-17-71.
The number 2 is difficult to see on the 326564 part number that is stamped on the support.
According to my Chevrolet Parts History for service parts GM # 326564 replaced GM # 3992376 in July 1972.
This 326564 support can also be used on 1970 and 1971 Camaro models that use the 3992376 support as they are almost identical.
NOTE: This support is not for 1972 Z28 models which uses the 6261814 support.
$8 for the used cable support plus shipping and Paypal fee (if applicable).
DCL70
1,969
The South of N.H.
For Sale: N.O.S. (New Old Stock) Accelerator Pedal, GM # 3920296, for 1970-1981 Camaro models as well as other GM models as listed in my vintage Chevrolet parts catalogs in Gr. 3.451. GM # 3920296 is also listed in my 1970 Camaro Assembly Manual (UPC 6, Sheet D3).
$12 for the N.O.S. Accelerator Pedal plus shipping and Paypal fee (if applicable).
I also have other used accelerator pedal linkage parts if needed. If interested or if there are any questions, send me a PM.
Dave
SOLD
DCL70
1,969
The South of N.H.
For Sale: N.O.S. (New Old Stock) Choke Thermostat Assembly, GM # 3972186, for 1970 All models w/2BC (350)(exc. E.E.C.) as per my 1970 and 1972 Chevrolet Parts Catalogs (Oct. 1970 and Jan. 1972) in Gr. 3.750.
Also included, but not pictured, is an aftermarket #10-24 X 1/4" domed head Phillips screw that attaches the choke thermostat to the intake manifold as shown in the 1970 Camaro assembly Manual (UPC 6, Sheet C2). This screw appears to be identical to the original screw, GM # 159853.
$10 for the N.O.S. 3972186 Choke Therm. Asm. plus shipping and PayPal fee (if applicable).
Dave
stafs05
604
chicago,IL
Dave
View attachment 129223 View attachment 129224 View attachment 129225
Dave can you please put this in my box, Of purchases. Thank you
stafs05
604
chicago,IL
For Sale: N.O.S. (New Old Stock) AC Delco Speedometer Cable, GM # 88959478 in Gr. 4.342. The cable is still in the sealed AC Delco wrapper. As shown in photo #5 the length of the cable is 77.8" long. The buyer should check to see if this cable is a suitable length for his or her car. Summit sells this cable for $50.99. Amazon sells it for $37.94.
View attachment 129210 View attachment 129211 View attachment 129212 View attachment 129213 View attachment 129214
stafs05
604
chicago,IL
Dave do you know if this is correct for 1970 SS Camaro with a TURBO 350 transmission? You are wiser thank me. Thank you
