N.O.S. & Used Original Parts For Sale - 2021
Discussion in 'Swap Meet Section' started by DCL70, Jan 7, 2021.
  1. DCL70
    DCL70 Veteran Member
    1,483
    32
    May 5, 2007
    The South of N.H.
    Off to eBay.
  2. stafs05
    465
    36
    Dec 26, 2007
    chicago,IL
    Can I buy the June U forging "OF". Thank you
  3. DCL70
    1,483
    32
    May 5, 2007
    The South of N.H.
    The only lug wrenches that I currently have for sale are the 1970 Monte Carlo lug wrench with the letter "O" forged on the lug head and the lug wrench painted gray without any markings. Both of these lug wrenches are SIMILAR to original lug wrenches that I have owned in the part but have long been sold. I have about 75 other lug wrenches (both 3/4" hex and 13/16" hex) that I have collected in the last 30 years and there many variations. Send me a PM.
  4. DCL70
    1,483
    32
    May 5, 2007
    The South of N.H.
    For Sale: Original 1971-1974 Camaro, Chevelle, Nova, Monte Carlo, and Chevrolet LH Exhaust Manifold with A.I.R. holes dated January 29, 1974. The LH exhaust manifold has a 3989041 casting number and is dated
    "A 29 4". The exhaust manifold has 3 reasonably good A.I.R. threaded holes that should be cleaned up by re-tapping and 1 A.I.R. hole that needs some work (see photo #4). The 3 studs are also broken and need to be replaced (see photo #12). Do not buy this exhaust manifold unless you have some experience in restoring exhaust manifolds.
    $25 for the exhaust manifold plus shipping and PayPal (if applicable).
    If interested send me a PM. Dave
    Exhaust Manifold 3989041 dated  A-29-4 - 1 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 2 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 3 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 4 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 5 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 6 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 7 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 8 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 9 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 10 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 11 of 12.jpg Exhaust Manifold 3989041 dated  A-29-4 - 12 of 12.jpg
  5. DCL70
    1,483
    32
    May 5, 2007
    The South of N.H.
    For Sale: Original 1972-1974 Camaro, Chevelle, Nova, Monte Carlo, and Chevrolet RH Exhaust Manifold with A.I.R. holes. The RH exhaust manifold has a 3959562 casting number. The other numbers and letters on this exhaust manifold are "RH", "7K" and "13" as shown in photo #2. I am a bit confused about what is the casting date. This exhaust manifold has one reasonably good A.I.R. hole (see photo # 3), two A.I.R. threaded holes with "frozen" plugs in the as shown in photo #4 as well as one A.I.R. hole with a broken "easy out" in the "frozen" plug (see photo #5). The 3 studs are also broken and need to be replaced (see photo #10).
    Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 1 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 2 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 3 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 4 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 5 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 6 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 7 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 8 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 9 of 10.jpg Exhaust Manifold 3959562 RH 7K w-A.I.R. holes - 10 of 10.jpg
  6. DCL70
    1,483
    32
    May 5, 2007
    The South of N.H.
    For Sale: Used Original "California" 34" long "square cross sectional type" bumper jack column and matching base (GM # 3756292).
    Off to eBay.
  7. DCL70
    1,483
    32
    May 5, 2007
    The South of N.H.
    For Sale: N.O.S. (New Old Stock) Delco Heater Blower Motor stamped "5044795", "5I", and "257 3" (257 day of 1973 or September 14, 1973). This motor would be "correct" for an early 1974 Camaro without A.C. The motor is also stamped "DELCO PRODUCTS" and "DAYTON, OHIO U.S.A." The shaft of this motor has a "double flat" shaft and uses the Double Flat Fan Package, GM # 3027031 as indicated on the instruction sheet. I do not have the fan. The 3027031 GM package includes the fan which has the number "3027437" on it as well as the attaching hardware.
    Note: The part number stamped on GM heater blower motors is not the same as the GM part number on the same part sold over the counter.
    According to my 1973, 1974, 1975, 1976, 1977, and 1981 Chevrolet Parts Catalogs the GM part number for this motor is 4960505 for 1973-1979 Camaro models as well as other Chevrolet models without A.C. The 4960506 motor can be used on older Chevrolet and GM models without A.C. but the "double flat" fan must be used.
    According to Chevrolet and GM Parts History for parts sold over the counter GM # 5044531 was replaced with GM # 4914901 in May 1968 which was then replaced by GM # 4918686 in March 1970 which was then replaced by GM # 4960505 in April 1973 which was then replaced with GM # 22010453 which was then replaced with GM # 22021257 which was then replaced with GM # 22048573.
    $50
    for the N.O.S. Delco 5044795 heater blower motor plus shipping cost and PayPal fee (if applicable).
    Heater Blower Motor NOS 5044795 - 1 of 9.jpg Heater Blower Motor NOS 5044795 - 2 of 9.jpg Heater Blower Motor NOS 5044795 - 3 of 9.jpg Heater Blower Motor NOS 5044795 - 4 of 9.jpg Heater Blower Motor NOS 5044795 - 5 of 9.jpg Heater Blower Motor NOS 5044795 - 6 of 9.jpg Heater Blower Motor NOS 5044795 - 7 of 9.jpg Heater Blower Motor NOS 5044795 - 8 of 9.jpg Heater Blower Motor NOS 5044795 - 9 of 9.jpg
  8. DCL70
    1,483
    32
    May 5, 2007
    The South of N.H.
    For Sale: 4 N.O.S. U-joints in white boxes stamped "386451" and "J5-153-1004". Each N.O.S. U-joint has "U.S.A." on one side and "S" and "455" on the other side.
    I also have one N.O.S. U-joint in a GM box with part # 386451. This U-joint is only a forged letter "S" (about 1/8" in size) on the center section but only on one side. The caps are plain. I only have one.
    All 5 U-joints are the same part number but are not the same type of construction. They are made by the same company ("S" forging, maybe for Spricer???) but were probably made at different times.
    NOTE #1: All 5-U-Joints each come with grease fitting.
    NOTE #2: Photo #9 is from my 1970 Chevrolet Parts Catalog.
    $20 for each N.O.S. 386451 U-Joint plus shipping cost and PayPal fee (if applicable).
    NOS U-JOINT IN GM BOX HAS BEEN SOLD.
    2 NOS U-JOINTS IN WHITE BOXES HAVE BEEN SOLD.
    2 NOS U-JOINTS IN WHITE BOXES STILL AVAILABLE.
    DSCN5513.jpg DSCN5514.jpg DSCN5516.jpg DSCN5517.jpg DSCN5518.jpg DSCN5519.jpg DSCN5520.jpg DSCN5521.jpg
  9. DCL70
    1,483
    32
    May 5, 2007
    The South of N.H.
    For Sale: 2 USED U-joints with Chevrolet "bow tie" markings. These U-joints have 24 roller bearings inside the caps. I assume that they are GM # 3955571 in Gr. 5.548 as shown in my 1970 Chevrolet Parts Catalogs (Oct. 1970), See photo #6.
    My 1970 Chevrolet Parts Catalogs (Sept. 1969, Nov. 1969, and Jan. 1970 ) list GM # 3955571 for All 1970 Chevrolet models and GM # 386451 for the 1970 Camaro w/T.H. 400 as well as other Chevrolet models.
    NOTES: These are used U-joints and I have no idea if they are still any good. Maybe they belong on a shelf just for show.
    $10 for the pair of used "bow tie" U-Joints plus shipping cost and PayPal fee (if applicable).
    (Shipping will be in a USPS Priority Small Flat Rate Box for $8.45)
    Dave
    SOLD
    U-Joint used Bow Tie - 1 of 5.jpg U-Joint used Bow Tie - 2 of 5.jpg U-Joint used Bow Tie - 3 of 5.jpg U-Joint used Bow Tie - 4 of 5.jpg U-Joint used Bow Tie - 5 of 5.jpg
  10. 70lt1z28
    4,090
    925
    Oct 3, 1999
    Beavercreek, Ohio, USA
    On sent
