Need better brakes
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by valleyguy, Feb 19, 2020.
  1. valleyguy
    valleyguy Veteran Member
    151
    Jul 15, 2018
    71 Camaro; I converted the manual brake setup to power booster (disc front, drums rear, stock sizes); definitely not satisfied with braking performance, even though I went through all the recommended steps when making this modification; changed the position of the booster rod on the pedal, etc.; wondering if bigger rotors, better pads, etc. will help. thoughts??
  2. Vettenick
    Vettenick Vettenick
    207
    31
    Jul 17, 2019
    What are you trying to accomplish? Is this for street, Track, etc?
  3. G72Zed
    G72Zed Veteran Member
    1,535
    477
    Sep 8, 2015
    First thing that comes to mind is how much vacuum is the engine producing, without being in the 15-18" range, you may not get everything out of the system. A good set of pads can make a big difference, enough so that the tires grip begins to be the limiting factor.
    hubedobeedo likes this.
  4. badazz81z28
    17,814
    711
    Alabama
    A healthy and properly working OEM system will lock the brakes up under full pedal. Is everything new? My guess is going to be air in the system, rear brakes are not adjusted. What proportioning valve are you using?
    Did you drill a new hole in the pedal? I honestly don't know the difference as a reproduction pedal only comes one way from what I have seen.
  5. xten
    xten Veteran Member
    3,388
    2,171
    Sep 24, 2014
    Pittsburgh, Pa.
    What is a good front pad for this setup (stock disc/drum)?
  6. Dave Nelson
    Dave Nelson Veteran Member
    4,708
    3,005
    Dec 19, 2003
    Vineland N.J USA
    Hawk pads HB103F HPS compound are good pads.
    dale68z and xten like this.
  7. COPO
    18,820
    1,216
    I have 11-12” of vacuum at idle and have no problems with Napa TruStop part # TS728AM Semi Metallic in the past and I'm currently using Raybestos Element 3 part # EHT52 (best attributes of ceramic and semi-metallic all in one pad).
    I have no issues with either brand pads. I only changed to the Raybestos pads because I replaced my original 70 Z28 rotors with Raybestos 5214R. Don’t forget to follow pad and rotor breakin procedures per manf.
    xten likes this.
  8. G72Zed
    1,535
    477
    Sep 8, 2015
    Good points from badazz, I know my original brake pedal had 2 holes, 1 for manual and one for power, there was no manual/power pedals, there all the same. Aftermarket may just be producing a "power" version as not much people go manual brakes these days.
  9. G72Zed
    1,535
    477
    Sep 8, 2015
    Well, I use 13"/12.2" disks with adj. prop valve that i adjust in the car, so not fair in comparing to a disk/drum setup.
    But I have been using the Wilwood BP10, BP20's an experimental pad (Q-E) they made for me, and have had good results with Hawk HPS, and on the heavy braking road course, the Hawk HP+ in the front, they screech and dust up like a SOB when cold, but they work great when you get heat in them. I use the HPS on the autocross, or BP10's, did not like the BP20's as much.
    xten and hubedobeedo like this.
  10. hubedobeedo
    hubedobeedo 3rd times a charm
    524
    166
    Jul 18, 2013
    Huntertown,IN
    need detailed set up and what you are testing(specific)
