Ok, I'm helping a friend of mine with his 77 Camaro and need some help to figure out where his 60' is? What were working with is
1977 Camaro
3400 lbs.
13.5-1 383ci stroker
Luniti solid roller 642 lift 272 dur
AFR 220 aluminum heads 2.08 1.6 valves
Match ported aluminum single plane intake
1040 cfm 4150 Biggs carb built for motor
6AL with new pro billet
1 3/4" headers
TH350 manual Valve body
Continintal 5200 stall 8" converter
Nine inch ford with 4.56 gear (now)
Moroso trick springs in front
Cal tracks out back
28/10.5/15 MT slicks
Hears the story lol, He had a 800cfm Edelbrock carb and a Huges GM4500 stall converter in the car and was running 12.0 at 112mph 1.60 60' and was looking for more power like most of us. So he called up Biggs carbs and ordered a custom built carb. They told him he needed a stage five 1040cfm 4150 so thats what he got. He put it on the car and gained mph but lost ET and 60'. He called them and they told him it was due to the converter being to tight. Ok, so he ordered a new converter. This kind of stuff has kept happening to him. He had 1 1/2" headers so he got new ones. Tried changing gear everywhere from 4.10-5.14! No matter what he has done to the car it allways runs 12.0 - 12.20 with a 1.7-1.8 60'. I found it very odd that with all of these changes Nothing! has changed the ET for the better or worse. My opinon is that this car should run in the mid 11.s but just wont 60' I am pleading for some help because I'm totaly lost? Thanks in advance for the help guys!
1977 Camaro
3400 lbs.
1 3/4" headers
Cal tracks out back
