Need Help Fixing Paint Pop
Discussion in 'Body Restoration' started by Lars_2Gen, Mar 28, 2021.
  1. Lars_2Gen
    Lars_2Gen Veteran Member
    765
    283
    Dec 29, 2017
    Fullerton, CA
    Got my car back from paint a while back with some issues... long story but the shop was unwilling to fix. Now i need to deal with them.
    This is on the dash - which they weren't supposed to paint - but my plan is to try to wet sand and then reclear with a semi gloss.
    Any advice on the best way to fix it?
  2. 80sz
    80sz Veteran Member
    3,916
    745
    Feb 2, 2014
    Buffalo,n.y.
    I’d sand also, try some 1500 or 2000. Your paint bubbled when they dried car in booth? Looks like can sand down re polish with out clear possibly
  3. badazz81z28
    20,936
    1,470
    Alabama
    Agree, you can sand it down and use a nice semi gloss black. I used rattle can on mine and lightly sanded it to give it a nice smooth sheen. Not flat black, but not glossy at all!
  4. Rosster
    Rosster Veteran Member Gold Member
    599
    301
    Mar 1, 2020
    If that is how they let it go out, everything else is suspect. Damn that’s pathetic quality work.
  5. arm2004
    arm2004 Veteran Member
    163
    48
    May 5, 2017
    S.E. Ohio
    I would sand down smooth and repaint with satin hot rod black single stage- not to shinny not to dull and still has UV protection. does the rest of the paint have solvent pop?
  6. Lars_2Gen
    765
    283
    Dec 29, 2017
    Fullerton, CA
    Thanks everyone for the advice.
    No the dash is the only area that is like this. The rest of the car looks pretty good.
    At this point in going to grab some 1000 and 1500 wet/dry and see how it comes out.
  7. 73Z L92
    73Z L92 Veteran Member
    230
    87
    Jan 25, 2011
    Carlos, MN
    My .02 is that it's silicone that wasn't removed properly. I would sand it down to bare metal. Dawn dish wash detergent and then 2-3 cleanings with wax and grease remover. Silicone is tough to get rid of.
    Again just my .02.
    roadrace2 likes this.
  8. Twisted_Metal
    29,904
    2,680
    ^ +1
    That's what it looks like to me.
    If those are fisheyes (pits) due to silicone... They are deep and you will need to sand it down smooth to get a clean start and level finish in the end.
    Silicone contaminated surfaces can be a bitch to fix. :(
    Sam's Z likes this.
  9. Rustbucket350
    Rustbucket350 Veteran Member
    1,052
    90
    Sep 4, 2013
    Oviedo, Florida
    Hate to break it to you but that's not solvent pop. You need to strip and refinish the dash.
  10. Stelan
    Stelan Member
    33
    16
    Mar 20, 2020
    silicone or armor all, you have to get rid of most of the paint and clean with solvents and repaint
