Need help with scavenged 406
Discussion in 'Engine Topic' started by Harold Cox, Feb 23, 2021.
  1. Harold Cox
    Harold Cox New Member
    Feb 22, 2021
    Crossville Tennessee
    Basically Im concerned about performance.
    I have a zz4 long block I could use but I was hoping for more from a 406.
    Wasn’t that impressed with the zz4.
    So here is what I have for the 406 build.
    Heads? I have a nice set of 461's with 64cc chambers, 2.02/1.60 in good shape with hardened seats and drilled for 400 steam holes with screw in studs. Not the 461X
    But Im concerned that they may not allow enough air in and out and that with the 64 cc chamber I may be pushing my CR for 93 octane.
    I would like to use the parts I have simply because of economics but if its not going to perform then I need to make changes.
    I could spring for a set of heads…Not vortec please. Something aftermarket.
    Heres a list of what I have
    406
    Bore:4.125
    12.5 cc dish piston
    5.7 eagle rods with apr blots
    Stock crank
    Dual-plane performer intake
    750 double pumper
    Double timing chain and gears
    Rotating assembly balanced.
    Block has not been decked
    Summit Racing Part Number:CCA-CL12-239-3
    Hydraulic flat tappet
    Duration 262/270
    Lobe separation: 111 deg.
    RPM Range:1,300-5,600
    Intake Valve Lift 0.462 in.
    Exhaust Valve Lift 0.480 in.
    But I have a few sets of 1.6 / 1.5 roller rockers if needed.
    Grind Number:CS X4 262H-11
    Im curious about the torque and horsepower with this set up and the performance I can expect.
    Built power glide
    3:36 10 bolt
    1966 Chevelle
    Thanks.
  2. 1320feet
    1320feet Veteran Member
    295
    110
    Oct 23, 2019
    Calgary, Alberta.
    Keep your 461 heads. I get 10.05 comp ratio using 64cc chamber, 12.5cc piston, .039 felpro head gasket and piston down the hole .025. It will make great low end torque with that cam. I don't worry about tight quench. It's not as important as most on the internet think.
    sooner likes this.
  3. Harold Cox
    Feb 22, 2021
    Thanks!
  4. G72Zed
    G72Zed Veteran Member
    2,360
    1,032
    Sep 8, 2015
    If your at a 4.125 bore, your at 400.9 cubic inches and not 406, and to hit a 10:1 CR @ 400.9 ci you need a total of 91cc @ TDC. I would not trek higher with that iron head on pump gas, even more so if your un-decked and piston to head comes in @ .064 like 1320feet states, not to mention the PG.
    Those 461 heads come in around 1.8-1.85 sq in at the pinch, and with a 2.02 and good valve job your approx. in the 210-220 cfm range +/-.
    Looking at the specs, your HP will peak around 5k rpm or so, and you will have very good TQ down low to match up with the PG's 1.76 1st and 3;36's.
  5. Harold Cox
    Feb 22, 2021
    I'm sorry. bore is 4.156 (400 30 over)
    Thanks! Great info!
  6. 1320feet
    295
    110
    Oct 23, 2019
    Calgary, Alberta.
    That jumps comp ratio to 10.18.
  7. G72Zed
    2,360
    1,032
    Sep 8, 2015
    In that case you have a 407 cubic inch and you need 92.5cc @ TDC to hit 10:1 CR.
    Adding this up, with a 12.5cc -dish, 64cc chamber, .5cc crevice volume and a 9cc HG (FelPro 1014) gives you 86cc, the piston in the hole needs to get you another 6.5cc. And it's not the best way by going that route, but doable.
  8. 1980RS
    1980RS Veteran Member
    4,859
    1,453
    Jun 17, 2006
    MN
    Ya I guess running high 10's with mild Vortec heads is out of the question, remember bigger heads don't always make big performance.
  9. sandlapper
    sandlapper Veteran Member
    501
    161
    Oct 9, 2020
    SE CSA
  10. G72Zed
    2,360
    1,032
    Sep 8, 2015
    Just make sure there's no overhang with a 4.165 HG on a 4.155 bore, that's tight, and you can make your own steam holes.
    I hate "crevice volumes" stack up....be it low top ring placement or overly big bore HG for the application.
