Need information about Holley Intake
Discussion in 'Engine Topic' started by Vicious, Apr 4, 2019.
  1. Vicious
    Vicious New Member
    29
    Dec 7, 2018
    Southern Maryland
    I have a Holley Street Dominator intake that I'm trying to learn more about.
    I read on a post from 2004 that there are at least 3 variants that carry the Street Dominator name. One is great, one is OK, and one is junk. The pictures from this thread are no longer available, so I can't tell which is which.
    It's some what similar to the intake in the picture (I initially thought they were the same) but I don't believe mine is a spread bore. (see pictures of the actual intake further below). Also the one in this picture doesn't have a freeze plug in the front.
    Any info you could provide would be appreciated (model number).
    It's currently sitting on my solid lifter '73 Z, with an Edelbrock 1813 Thunder Series (I believe it is 800 cfm). Luckily, the car has a 4spd, because if I don't goose the throttle and give it a lot of gas off of idle, it wants to bog down. Other than that, it seems to perform pretty well.
  2. 1980RS
    1980RS Veteran Member
    4,694
    1,367
    Jun 17, 2006
    MN
    That intake is kind of weak on a smaller SBC, but on a 350 or larger it should work pretty good. The 800 thunder carburetor is a really good, I went 12.02 a couple of years ago on my peanut port engine when I got to test my buddies out for him and that was with no tuning other than setting the secondary door a little. If you could get those runner dividers extended into the plenum area I bet that would really help.
  3. Vicious
    Vicious New Member
    29
    Dec 7, 2018
    Southern Maryland
    Do you know the model number?
  4. jeff swisher
    jeff swisher Veteran Member
    1,727
    573
    Apr 26, 2018
    Yukon Oklahoma
    I remember those intakes from many years ago and the advertisement was Idle to 4800 RPM.
    I got one for 20 bucks and it was for an oldsmobile 350" and I tried it vs the Qjet iron intake.
    Very little gain but there was a gain. It was at the upper end of the rpm range.
    I later would remove it and port the plenum on the Qjet intake and trumped that lighter intake everywhere.
    Old folks liked single planes and hood clearance. So they turned out some odd junk.
    That is my theory.
    Would I run one today.
    NO WAY.
    Would I run the old flat floor Edelbrock performer intake?
    NO WAY. I hate that one also.
    Some people like it though.
    There are a few intakes I tried and they just failed miserably and not worth even trying to sell.. most I give away if I end up with them.
    That is my Take on 2 intakes.
    I suppose if you do not have another intake and no money and you have that one then it will work.
  5. theflash
    11,044
    36
    Feb 27, 2004
    Podunk, CT
    That's a spread bore intake, and your carb if I'm not mistaken is a square bore, so unless you have some kind of adapter plate, that's not the same intake you have.
  6. Vicious
    Vicious New Member
    29
    Dec 7, 2018
    Southern Maryland
    I hadn't noticed that. I went back and recompared the two, and mine is flat in the front where the carb mates to the intake. Now I'm really confused.
  7. Vicious
    Vicious New Member
    29
    Dec 7, 2018
    Southern Maryland
    Here's a few more pics of the actual intake
  8. Vicious
    Vicious New Member
    29
    Dec 7, 2018
    Southern Maryland
    Ok, at this point I'M relatively certain that it's a 701R-1/300-1, AND it is a spread bore. I've also read that Edelbrock carbs are wide enough to seal the manifold without the need for an adapter. The car has a vacuum gage, and I have good vacuum pressure, so it must be sealing properly.
    I'm pretty sure this is the exact intake I have.
  9. RS1979
    3,974
    917
    Jun 18, 2013
    Memphis, TN
    That is a 700r-1 300-1. They are good from 0-4800 rpm. Save your money and get a Holley 300-36. I use one and I love it.
  10. GoldenOne7710
    5,310
    716
    Jun 23, 2004
    Athens, GA
    Holley discontinued the 300-36 several years ago. You can still find them here and there. They had an advertised power range of off-idle to 7200 RPM. For that reason, they were probably one of the most versatile intake manifolds ever made. I have one too and wouldn't trade it for any other SBC intake.
