Need some input
Discussion in 'The BS Topic' started by flowjoe, Oct 22, 2014.
  1. flowjoe
    8,058
    46
    Feb 7, 2006
    SoCal
    I needed to unscrew the check valve from the AIR tubes just above the manifold/header on the '82 'Vette. I got lucky and it wasn't seized/rusted together. I now need to reinstall the check valve and am wondering if it would be advisable to put anti-seize on the threads before I do. Will the anti-seize work in a high heat environment like that? Will it help for future removal (it needs to be removed anytime one wants to remove the valve cover:mad: ) or will it make things worse? Maybe it's not as hot as I think since the check valve is fed by a rubber hose and the issue is therefore moot.
    I stuck this here rather than a specific tech forum because it really didn't fit into any category.
    Thanks in advance for your thoughts on this.
  2. muscl car
    23,448
    1,841
    Jul 8, 2001
    Hendersonville Tennessee
    Joe ... i use anti seize on the pan evac check valves that are located on the header collectors , Haven't had any issues at all
  3. BonzoHansen
    20,897
    1,862
    Jun 1, 2005
    Scott from Hamilton, NJ
    yes anti-seize
  4. COPO
    21,195
    2,671
    I use anti-seize on my exhaust manifold bolts and when they get removed for whatever reason the anti-seize is still on the threads. So it looks like the anti-seize does not get burnt off.
  5. Todd80Z28
    11,869
    431
    Jun 11, 2002
    Northern VA
    Can't hurt. Anti seize is commonly used on O2 sensors (run with it Dave & Mike):).
  6. Ztoy
    Ztoy Veteran Member Lifetime Gold Member
    3,932
    May 4, 2003
    Ionia, Michigan
    Anti seize, absolutely.
  7. Twisted_Metal
    30,180
    2,890
    "If it's loose, duct tape. If it's tight, WD-40!"
    For things like O2 sensors, check valves and header bolts... There are addendums to that rule:
    For something tight that you'll want to get loose in the future, anti-seize.
    For something tight that you want to stay tight, Lock Tite.
    For something loose you never want to take apart, JB Weld.
  8. flowjoe
    8,058
    46
    Feb 7, 2006
    SoCal
    Thanks for the responses guys. Didn't want to go with a gut instinct and have it turn out badly. I had considered the whole header bolt thing when contemplating this path but decided, perhaps erroneously, that they didn't see the same sort of heat at the thread end.
  9. rscamaro73
    rscamaro73 Administrator Staff Member
    14,977
    17
    May 30, 1999
    Striking fear and destroying the enemy
    If you really look deep.....you'll find COPPER ANTI SEIZE.
    It'll handle higher temps and last longer overall.
    But its 4 times as expensive. But I recommend it.....
  10. flowjoe
    8,058
    46
    Feb 7, 2006
    SoCal
    I'd totally forgotten about copper anti seize. Oh well, I didn't have any here anyway and I really needed to get the car buttoned up again.
