• The Forum will be unavailable on March 27, 2023 from 8:AM to 12:00 PM EST for maintenance.
Need some paint advice, not Camaro.
Knuckle Dragger
Mayor of Simpleton
17,083
Waddell AZ
I have a S10 Blazer I'm putting a 5.3 in to make it a fun daily driver. The bumper was messed up so I got a replacement and decided to give painting it a shot with some of the automotive aerosols out there. I did some work on my Nova years back and they turned out OK. I'm not driving shop pieces by any stretch.
While color sanding it I got too aggressive and sanded through the clear, the base and my primer all the way to the black primer that was on the bumper from the manufacture. I tried to post a picture but it won't let me.
I'm not looking for perfect but this obviously isn't what I wanted. What do I do now? Can I sand back with 600 again, seal and re-shoot everything?
I don't think I had enough base on it to begin with. I only bought one can and because I used the white primer I had a hard time seeing the coverage. The spray nozzle was poo for the first coat but I swapped it for the primer nozzle and the next two coats came out OK. I was chasing an flat even finish when I was trying to sand out "shiny dots" I thought were low spots in the clear and just go too aggressive when I sanded through. I definitely need to position the work better on the next try.
Any advice is appreciated.
Knuckle Dragger
Mayor of Simpleton
17,083
Waddell AZ
Here is the picture
Knuckle Dragger
Mayor of Simpleton
17,083
Waddell AZ
Feather it out best you can, scuff remainder of paint, re-seal and start from there - redo whole bumper since you're concerned about material depth.
Right on, that's the plan then.
I got to do a better job positioning the work so I can lay it out right. I think I was doomed from the start by not slowing down and taking my time.
jester1
2,446
If you hit the manufactures black primer while sanding give it a shot of adhesion promoter if you have some laying around. Feather it out too.
