Need Tips for fixing rust bubble on rear edge of trunk
Discussion in 'Body Restoration' started by Rosster, Sep 14, 2020.
  1. Rosster
    Rosster Veteran Member Gold Member
    172
    71
    Mar 1, 2020
    My 70 has a few minor rust bubbles in the very edge of the panel Near where the metal folds over to secure the skin to the Trunk inner frame. Other than that it is perfect. Guessing it’s moisture caught between the skin and trunk frame. What is the proper way to repair this permanently?
    KingofThings likes this.
  2. mallard
    mallard Veteran Member
    873
    227
    Oct 3, 2013
    SK, Canada
    pics?
  3. Revin
    Revin Veteran Member
    592
    102
    Aug 31, 2016
    Round Rock , TEXAS
    Sand down to good metal.
    Cut out bad rust, Patch.
    Primer it for paint
    KingofThings and badazz81z28 like this.
  4. badazz81z28
    18,836
    988
    Alabama
    This is the right way, but depending on where it is, might be difficult. You can also sand it down and metal filler over the pits. This is why I want a pristine trunk lid.
  5. Rosster
    172
    71
    Mar 1, 2020
    Here’s pics of problem. Otherwise it very clean lid. Going to get car painted as part of restoration process so do’nt want this coming back.
    8BE5A6CA-7D54-4AE3-92D5-15504AB113A8.jpeg CE0C440C-4D10-438F-8877-BAA07F18BCE9.jpeg 5DE5D3DF-F6B2-4822-906C-4589612FB68B.jpeg
  6. COPO
    19,447
    1,557
    When that area gets fixed soak that trunk panel with rustproofing or WD-40.
  7. mallard
    873
    227
    Oct 3, 2013
    SK, Canada
    Any pics from inside that edge?
  8. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,887
    118
    Jul 31, 2001
    Ft. Lauderdale, FL
    Depends a lot on what you want, and where you take it. The shop that my car was in, the guys might tell you to get a new lid if it had spots like that. Faster, better and cheaper because what you see now can be a whole lot different when you start sanding
    Labor hours add up frigging quick as hell on rust repairs. That's something the " Cut out, Patch, Fill, Sand, Primer guys " aren't telling you
    Thats moisture from the inside, and that's where you find all kinds of nice e surprises when the work starts .
    Ask me how......
    serpent710 and KingofThings like this.
  9. steins70z28
    steins70z28 Veteran Member
    284
    44
    Apr 14, 2012
    Tulsa, OK
    Definately need to be ground down to bare metal and cut out the area so you can see if the issue is confined to just that area. The inside needs to be blasted and treated to stop the rust. If the rust runs the whole length of the trunk but hasn't busted through it will cause problems you don't want to deal with after you've paid $$$ for a paint job. If the lip on the inside shows no sign of issues you might be able to just repair that area.
  10. COPO
    19,447
    1,557
    I ended up buying a new trunk lid in ‘85 from GM when my car was done. Would have had too much time wasted on it.
