72 Camaro that I converted from an automatic to a Tremec 5spd. Built a 383 stroker and now i'm installing an AAW wiring harness. To bypass the NSS can I splice the two purple wires together? Wire 1: 12v feed 'in' to NSS from ignition switch. Wire 2: 12v feed 'out' to starter solenoid. Thanks!
Why would you want to bypass a safety feature? If you belong to any car club that requires tech inspections, such as NSRA, you will be required to have it. Here is a simple diagram:
