NEW 74 Z28
Discussion in '1974 Specific' started by John74z, Feb 13, 2019.
  1. John74z
    John74z New Member
    8
    Jan 30, 2019
    I don’t think it’s been in NY but definitely the northeast. Yes it does have a long list of options. I’m have the build sheet. My plans for now are to drive it and enjoy It. Any opinions on oil (mobile1 15w-50) coolant, and especially whether i should change transmission fluid ? And can you guys tell whether things like the radiator and alternator are original? Thanks
  2. Jonesy
    Jonesy Veteran Member
    487
    33
    Jun 7, 2008
    Minnesota
    I couldn't see the alternator very well. You will have to see what numbers are stamped on it. Originals are stamped 1102397.
    Here is an example:
    radiator cap looks to be the original and theres a chance the rad is original.
  3. 74Z28GC3
    74Z28GC3 Veteran Member
    1,743
    62
    Sep 1, 2000
    North Pole, Alaska
    The alternator for a 74 Z28 that has AC in them is part number 1100597 (61 amp). 74 Z28 without AC had 1102397 (37 amp) alternators in them. Please checkout this thread by me and other member who have 74 Z28's with AC.
    http://www.nastyz28.com/threads/74-z28-alternator-question.202124/
    Your radiator cap is correct like Jonesy stated in a previous post. I am not sure about your radiator. An original radiator should have Harrison engraved on it with codes on a tag attached to it. Please click on the link below about the part number that s for an original Harrison radiator that came in automatic 74 Z28's.
    http://www.nastyz28.com/threads/74-z28-radiator-tank-and-tag-info-needed.228556/
  4. zfool
    zfool Veteran Member
    610
    23
    May 19, 2014
    Rochester, MN
    Nice car, I wonder if it’s the one that was on CL a year or so ago that was said to be owned by a woman since new. It was low miles but looked like it had moisture issues so maybe this isn’t the one.
    I’ve got almost all of the original parts numbers if you’re interested I can post them.
  5. CamaroNmotion
    CamaroNmotion Veteran Member
    359
    24
    Jan 8, 2006
    Buffalo, NY
    In regards to your radiator there are two things you can look for. On the tank portion.. (pass side near top) the word Harrison should be spelled out and also on pass side about half way down you should find a metal tag with numbers and letters embossed on it....since you have the buildsheet the letters should match with your buildsheet box 45. The numbers on tag should match numbers embossed also on tank pass side.
    Very nice car, welcome to this site.
  6. ZEN357
    ZEN357 Veteran Member
    384
    71
    Feb 12, 2018
    Congrats! Nice Car! What do you intend to do with it? Keep it original as possible or rebuild it with newer parts?
  7. dadgonebroke
    dadgonebroke Veteran Member
    354
    25
    Jul 1, 2008
    Nature Coast of Florida
    As far as synthetic oil- when I changed a vehicle that had been on conventional oil to synthetic- every vehicle developed oil leaks.
  8. zfool
    610
    23
    May 19, 2014
    Rochester, MN
  9. John74z
    John74z New Member
    8
    Jan 30, 2019
    Thanks for the info on the alternator and radiator. I have the V01 code for the H/D Radiator so in box 45 it says LT, so that’s what I’ll look for. Wondering if other people have had the same experience as dadgonebroke with synthetic oil where they developed leaks. And thanks zfool for that great list of part numbers.
  10. 70lt1z28
    3,625
    730
    Oct 3, 1999
    Beavercreek, Ohio, USA
    For the oil you've got a flat tappet cam so you might want to consider an oil with a high zinc content like Valvoline VRF or Brad Penn or something similar. Ever since the roller cams cam on board at the OEM level the oil companies have been reducing the zinc content as it is better for the catalytic converters. The zinc was in the old oils as the cam and tappets needed it to live. There have been thousands of posts about this on every automotive forum in the last 10 years or so. Do the research.
