new and used camaro parts for sale!!!
Discussion in 'Swap Meet Section' started by 70ish camaro, Nov 1, 2013.
  1. 70ish camaro
    70ish camaro Veteran Member
    277
    Apr 14, 2008
    mandeville, la
    Here is a mega list of mostly 70-81 generation camaro parts for sale. I added many new parts. There are some parts that are brand new, many that were used to mock up/test fire my old engine, some that have only a few hundred miles on them and only a few parts that are stock 1970's parts. I tried my best to tell which of these where in each time frame of usage. Any additional pictures needed please let me know and pm me with any questions about any of these items. Ill get back to you asap. All prices are plus shipping and will combined shipping if needed. Thanks for looking! NEW LOWERED PRICES!
    Mike
    1.) front upper grill. looks good, no cracks or breaks anywhere. $20 + shipping
    2.)SOLD
    3.)relay for a/c that mounts on outside box under hood. worked when on car. $4.00 + shipping
    4.) SBC long style water pump. Like brand new! ran only to test run motor. painted black with heavy duty paint $30.00 + shipping
    5.) new in box red caliper/brake drum paint. withstands temp up to 950 degrees. $20.00 + shipping
    6.)SOLD
    7.) 78-81 hood latch support. no rust, not bent and looks great $10.00 + shipping
    8.) camaro hood latch. cable pull removed. $10.00 + shipping
    9.)75-81 new chrome rear window trim. never installed.$100.00 for each set +shipping
    10.)SOLD
    11.)SOLD
    12.) 19x31 Northern Aluminum radiator. Used lightly, but looks great. universal type, modified to fit in stock location. It has 2- 1 inch rows inside, and no trans cooler.
    $120.00 + shipping
    13.)A/C bracket $5.00 + shipping
    14.)A/C bracket $5.00 + shipping
    15.) Right and Left door handles. They were new chrome and were painted black and now the paint is chipping off. $15.00 + shipping
    16.) Eight chrome valve cover hold down clamps. $8.00 + shipping
    17.) SOLD
    18.)SOLD
    19.) New low profile 14" air filter. $5.00 + shipping
    20.) Misc exhaust pieces $10.00 for everything + shipping
    21.) 70-81 rear drum brakes 9.5" complete from back plate to drum all rebuilt with a few hundred miles on them. just bolt on, bleed and go. 250.00 + shipping
    22.) SOLD
    23.)blue tubing cover $3.00 + shipping
  2. 70ish camaro
    277
    Apr 14, 2008
    mandeville, la
    24.) automatic transmission dipstick$10.00 + shipping
    25.)SOLD
    26.) New Delco Diaphram for master cylinder $8.00 + shipping
    27.) front defrost y-connector ducting. helps air travel from box to the dash vents that blow on the windshield. It has a small chip in the middle of it that needs to be repaired or covered $10.00 + shipping
    28.)SOLD
    29.) brake peddle from a 78 camaro. $12.00 + shipping
    30.) heat shield from a 78 camaro. was on the end of the passenger side sub-frame rail. $4.00 + shipping
    31.) Totally Stainless heater and air conditioning cover kit for a 70-81 camaro.$10.00 + shipping
    32.) like new Heavy Duty brass replacement radiator with automatic transmission cooler. direct fit and worked fantastic. used to test fire a motor, lie new!! $100.00 + shipping
    *will get picture later today*
    33.) idler arm frame bracket for a 78 camaro. may fit 70-81 camaro. $5.00 + shipping
    34.) seal that goes inside of cowl vent off of a 78 camaro.$5.00 + shipping
    35.) hood catch off a 78 camaro.$5.00 + shipping
    36.) new power steering lid for a 70-81 camaro.$3.00 + shipping
    37.) new 54" v-belt, spun cog. no cracks or dry rot at all. made in the USA. $6.00 + shipping
    38.) like new, 45" v-belt, spun cog. used for mock up only, never ran. no cracks or dry rot at all. made in the USA. $5.00 + shipping
    39.) like new, 42" v-belt, spun cog. used for mock up only, never ran. no cracks or dry rot at all. made in the USA. $5.00 + shipping
    40.) like new, 38" v-belt, spun cog. used for mock up only. no cracks or dry rot at all. made in the USA. $5.00 + shipping
    41.) SOLD
    42.) (there is TWO mufflers) Flowmaster 40 Series Muffler, American Thunder 40 Series 42441. These are for a 2.25 inch, but the inlet/oulet has been expanded so they would fit snuggly inside a 2.5" exhaust pipe. therefore they will fit a 2.5 $100.00 for both + shipping
    *will add picture later**
    43.) th350, completely rebuilt from the front to the back. has less than 500 miles, switched to a 5 Speed TKO so I dont need this anymore. It has hardened race sprags, and heavy duty cluthes and bands, with a stage 2 B&M shift kit.
    $450.00 + shipping
    44.) a 2400 stall converter that has less than 500 miles, Brand unsure, I think its a B&M... switched to a 5 speed TKO so I dont need this anymore.$125.00
    45.) New CD sunvisor holder $5.00 + shipping
    46.) SOLD
    47.) SOLD
    48.) SOLD
    49.)installed and used for only 500 miles 78-81 PUI white Camaro zipper back upholstery. front and rear seats. $200.00 + shipping
    50.)SOLD
    51.)lightly used chrome oer sill plates, looks new $30.00 + shipping
    52.)Sold one set, keeping the other
    53.)a lightly used oer 70-81 trunk drilled for a 3 piece spoiler $99.00 + shipping
    54.)a brand new white perforated headliner with new board attached$175.00 + shipping
    55.) Like new stock style remanufactured A/C compressor used with R134a used in a 78 camaro. Only about 500 miles on it....worked perfect! 175.00 + shipping
    56.)new 1970-81 CAMARO PROTECTOR FLOOR MAT for the front. left and right. 28.00 + shipping
    57.) SOLD
  3. BonzoHansen
    20,681
    1,774
    Jun 1, 2005
    Scott from Hamilton, NJ
    where is the rest of it?
  4. 70ish camaro
    277
    Apr 14, 2008
    mandeville, la
    forgot to update that one, my apologies. everything is updated now.
  5. cadmanmeg
    cadmanmeg Veteran Member
    1,754
    Mar 20, 2006
    Bothell, WA
    What is the rating on the springs? Can you PM your reply so it don't get lost? Thanks much.
  6. jfreakofkorn
    jfreakofkorn Veteran Member
    407
    Apr 20, 2010
    in a beer can ....
    whats the grille off of ....??
    i would be interested in it , if its for the i am thinking about
  7. mgoad1971
    mgoad1971 Veteran Member Lifetime Gold Member
    2,472
    Jul 29, 2011
    Houston, Texas
    Interested in 47, the sail panels. How used are they? Shipping to 77536, I can do paypal
  8. MagicRatt
    MagicRatt Veteran Member
    1,138
    18
    Aug 24, 2004
    Southampton, Pa.
    PM sent..........
  9. lumpy12
    lumpy12 Veteran Member Lifetime Gold Member
    727
    16
    Sep 16, 2012
    NorCal
    Check your PM's please - I'm interested in #17
  10. 70ish camaro
    277
    Apr 14, 2008
    mandeville, la
    PM sent
