New BBC won't fire???
Discussion in 'High Performance Modifications' started by fast72, Nov 23, 2012.
  1. fast72
    fast72 Veteran Member
    100
    Apr 3, 2009
    Sacramento, Ca
    BBC "509"
    4.500 Bore
    4.000 Stroke
    13.2 to 1 compression
    Comp Roller Cam 726/714 Lift 284/294 @ .050 on a 110 lc
    Rectangular Dart Pro 1' 325CC ported a lil bit
    Rectangular Dart Intake ported to heads
    Hooker Super Comp Headers 2" primary and 3 1/2" collector
    Digital 6 tested good
    SS coil tested good
    billet dist. tested good.
    Motor has spark, but when turning the motor over it sounds like it is retarded...Timing is setup properly??? Brand new rebuild on engine will not fire? Battery shows 12.4 volts and I put on the charger and it shows 12.5 but sounds like it is struggling to turn over...HELP
    Could it possibly be a dead cell in the battery and then when a load is put on it the power output dies?
  2. mrdragster1970
    7,821
    507
    Apr 12, 2007
    If you are sure you have the timing at 36, I would definitely try a new battery before wasting time on anything else.
    Then start in order, cables, connections, starter etc.
    Might even try dual batterys just to see if it makes a difference??
  3. SMCZ28
    SMCZ28 Veteran Member
    818
    Jun 15, 2010
    United States
    Remember fill the gas tank :D lol
  4. fast72
    100
    Apr 3, 2009
    Sacramento, Ca
    Got gas and it is not 180 out either.
  5. Hoot
    Hoot Veteran Member
    1,475
    Jul 12, 2008
    Greenville MS
    As stated. make sure battery is good. jump start with another battery maybe.
    Make sure you adjusted the valves properly.
    Good ground to engine and frame.
    firing order correct.
    seems like alot of compression for a normal starter.
    gas, spark and compression is what you need.
  6. grzewnicki
    3,601
    323
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Have you checked cell to cell in battery? pull caps, using VOM, check neg post to first cell (put pos lead in acid) should be about 2.0 volts, then work you way down the battery dipping leads in two holes right next to each other, then last will be neg lead in cell and pos lead on pos post. That will show you if you got a dead cell.
  7. 1970.5rs
    1970.5rs New Member
    16
    Sep 30, 2012
    Parsippany,nj
    Firing order correct .?
  8. Thunderkyss
    Thunderkyss Veteran Member
    223
    Sep 16, 2012
    Texas
    That's my question. If your engine is turning over fine (13.2 cr...... wow) I don't think you've got a battery issue.
    If it sounds retarded, I imagine a little backfire, a little lag in the rotation, so the ignition system is trying to do what it's supposed to, but may be out of sync.
    If the firing order is correct, I'd pull the front cover off & double check the cam/crank relationship. Make sure you don't have it 180 out.
  9. fast72
    100
    Apr 3, 2009
    Sacramento, Ca
    I am going to replace the battery with a known good battery...
    I don't have the means to test the cells etc; in the battery....
    Firing order is 18436572 All looks good there...Even ohm out the wires.
  10. markw
    markw Veteran Member
    820
    Jun 6, 2009
    Illinois
    Remember a timing light will work while cranking the motor. What kind of starter? Disconnect the ignition and see if it spins over freely.
