New best
Discussion in 'Competition Camaros' started by bracketracer-78, Jun 13, 2015.
  1. bracketracer-78
    bracketracer-78 Veteran Member
    763
    123
    Sep 5, 2003
    Stevens, PA USA
    Today the Camaro went 11.18 @ 120 mph. On that same pass in the shutdown area I lost the governor cover for the tranny. It also had a vibration after I slowed to about 50 mph.
  2. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    Sweet, that's movin!!!!!! If you ain't breakin, you ain't racing....
  3. bracketracer-78
    763
    123
    Sep 5, 2003
    Stevens, PA USA
    I got the cover back from a track official. I need to get the retainer clip for it. I'm also going to pull the driveshaft and inspect it for anything weird. The front u joint and slip yoke were brand new. I'm going to pull some gear out of it. My shift light comes on at 6800 and I am going through the traps at 7300.
  4. J78
    J78 New Member
    24
    Nov 3, 2003
    LOUISVILLE, KY
    How much gear is in it now?
  5. 79CamaroZ28
    79CamaroZ28 Veteran Member
    1,243
    Aug 1, 2001
    tucson, Arizona
    Clean everything up good. Make sure cover is in good shape and Throw the stupid o-ring in garbage. Use Red Lock tite on the cover surface where it is pressed into the case, Let it set up overnight before adding fluid. wont fly off again. Be sure to check the governer and gear while u have it apart.
  6. bracketracer-78
    763
    123
    Sep 5, 2003
    Stevens, PA USA
    4:56, I'm going to either change to 4:10's or I'm going to change from 28" tall tires to 30" tall tires.
  7. bracketracer-78
    763
    123
    Sep 5, 2003
    Stevens, PA USA
    There is no governor. It has a reverse manual valve body. I just bought 2 cans of brake clean. The track wants to see the spring clip over the cover but I will use the red lock tite. I am also going to pull the driveshaft. 3/4 of the way down the shutdown area there was a vibration right before the cover bailed out on me. I just had the front u joint and slip yoke changed out. It did not vibrate on the first pass but it will not hurt to take a look.
  8. sponge003
    sponge003 Veteran Member Gold Member
    1,510
    Jan 10, 2009
    Concord, NC
    I really liked running mine with 30" tires when they would fit before I changed springs.
    It seemed like the car was more consistent.... whether it really was is another discussion!!!
    More importantly they really filled the wheel wells and looked very cool!
