New Clutch Defect - Should I Install?
Discussion in 'Transmission & Driveline Topics' started by Rayden2009, Jul 25, 2020.
  1. Rayden2009
    Rayden2009 Veteran Member Gold Member
    162
    27
    May 12, 2016
    Calgary AB
    I just got my new Mcleod clutch from Summit and there is a defect in the pressure plate. It was delivered Friday and it was supposed to be my weekend project. Should I install this? I have a feeling I should return it for a new one but I'm not sure. I went through the trouble of machining my flywheel so I cant imagine this blemish in the pressure plate is okay. I wont be able to get ahold of Mcleod or Summit until Monday so I thought I would see what the consensus on here is.
    BFF692BA-EE88-4A91-820D-578BD4FBAEAA.jpeg 4314F0FD-EEAE-46BE-8A95-C1EC05CBFFBB.jpeg
  2. Twisted_Metal
    28,285
    1,678
    That chip shouldn't be there but I doubt it will be a problem to run it like that.
  3. 80sz
    80sz Veteran Member
    3,447
    515
    Feb 2, 2014
    Buffalo,n.y.
    No way, it goes back. New is new that’s a defect and I wouldn’t accept it
    Zstar likes this.
  4. COPO
    19,480
    1,587
    Chinese error, send it back if your fussy like me. I bought my Luk kit from a AC Delco Dealer in town so if there were problems then I wouldn’t be dealing with shipping and waiting for days.
    Zstar and tom3 like this.
  5. tom3
    tom3 Veteran Member
    12,952
    756
    Aug 1, 1999
    ohio
    Typical with Chinese casting. Probably a worse defect that can't be seen due to the cast/mold shift. And a re-machined flywheel can be some out of balance depending on how much balancing was done originally and how much was cut.
  6. Rayden2009
    162
    27
    May 12, 2016
    Calgary AB
    Thanks. Ill send it back. What a drag. I thought Mcleod was a US company? Maybe they just assemble in the US.
  7. DB Z28
    DB Z28 Veteran Member
    615
    73
    Nov 30, 2003
    Fond Du Lac
    Send it back garbage not worth it if the breaks then you have nothing. And run a steel bellbousing to save your feet
  8. Fbird
    4,922
    1,105
    Feb 12, 2011
    atlanta, ga
    I am of the philosophy "if it looks bad....must be bad"
    "If it looks GOOD ...it MIGHT WORK"
  9. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,887
    119
    Jul 31, 2001
    Ft. Lauderdale, FL
    Really looks to me like it got dropped and hit hard while it was still in the box. Get another for sure.
    Zstar likes this.
  10. Rayden2009
    162
    27
    May 12, 2016
    Calgary AB
    You wont believe this. Just got my replacement clutch in And it has the exact same defect in the exact same spot. Im just going to install it and cross my fingers. Im pretty disappointed.
