New Clutch Defect - Should I Install?
Discussion in 'Transmission & Driveline Topics' started by Rayden2009, Jul 25, 2020.
  1. frankz
    frankz Veteran Member
    2,121
    26
    Aug 24, 2009
    Illinois
    Hit it with a little Emery cloth and it should be just fine
  2. 1978 Z/28
    1978 Z/28 Veteran Member Gold Member
    220
    121
    Jul 17, 2017
    New Brunswick
    I trust CI as far as I can throw it, which is not far. If that passed safety inspection, then what can you not can not see would worry me. A friend of mine had a brand new Chev tow truck with less than a 1000 miles clutch blew up took off 1/2 right foot.
    Zstar likes this.
  3. 80sz
    80sz Veteran Member
    3,524
    529
    Feb 2, 2014
    Buffalo,n.y.
    I still wouldn’t run it and it prolly same one you sent back, how that happened 2x? Get a credit return. Man that’s some bs , I’d flung that thing like a ufo I woulda been so upset
    Zstar likes this.
  4. badazz81z28
    19,207
    1,087
    Alabama
    If you lay the disc on it, does that area part of the friction surface? If not, it shouldn’t be an issue. By looking at it, is this a stock power application piece?
  5. Rayden2009
    Rayden2009 Veteran Member Gold Member
    168
    29
    May 12, 2016
    Calgary AB
    Yes the friction plate overlaps the defect, so it could be an issue. The clutch is good for 500 hp which is much more power then I have.
  6. xten
    xten Veteran Member
    3,799
    2,639
    Sep 24, 2014
    Pittsburgh, Pa.
    No way would I put that in. I'd hate to see it blow apart. I would also wonder about balance. Sounds like they sent the first one back to you, or there's a bad lot of them. I've asked mechanics and gear heads around here, and with a street car there's no doubt I'm putting a LUK in mine.
    Zstar likes this.
  7. Rayden2009
    168
    29
    May 12, 2016
    Calgary AB
    There must be a bad batch because the first one was still on route back when they sent out the replacement. I guess ill send this one back too. Im ocd and I know ill be thinking about this clutch flying apart every time I lay in on the car or shift hard at high rpm.
    Zstar likes this.
  8. xten
    xten Veteran Member
    3,799
    2,639
    Sep 24, 2014
    Pittsburgh, Pa.
    I'd be the same way, either cringing at a high RPM shift, or just not doing it at all. That'd suck.
  9. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,906
    136
    Jul 31, 2001
    Ft. Lauderdale, FL
    I would NEVER even consider putting that in my car. Remember the Golden Rule......God helps people by sending them signs ..... right now he's trying to tell you not to be stupid.
    I played " Musical Clutches" for a while. The last one was a LUK ? sp? and it seems to be a lot better than any I've had before.
  10. Rayden2009
    168
    29
    May 12, 2016
    Calgary AB
    FYI - I installed the clutch. I called Mcleod and they said it was totally normal. They pulled one off the shelf that had the same thing while on the phone with me. I didn't want to go through all the hassle of another return. I only have a 4 month driving season up here. I think I messed something up though as the tranny doesn't shift as smooth as it did and I can here the throw out bearing engaging and disengaging. Sigh. The joys if learning on the fly.
