New floor pan question
Discussion in 'Body Restoration' started by Lonesomeloser, Jan 17, 2021.
  1. Lonesomeloser
    Lonesomeloser New Member
    15
    Apr 10, 2019
    Middletown, MD
    I received my new floor pan with braces and torque boxes. My questions is: Are the aftermarket welds sufficient around the torque box area? Would it be worth my time to add a few more really good welds in these areas? torque box floor pan.jpg torque box 2.jpg
  2. 76 for 26
    76 for 26 Member
    56
    22
    Dec 29, 2015
    NC
    When I welded mine in, I drilled holes in between those in the frame to cut the distance and cranked the welder up when I plug welded the floor to the new/used frame rails. Not sure that’s the best way to do it...hopefully. Be sure to make sure that pan is squared up prior to welding it in. I re-measured everything against the info on the datum sheets (or whatever they are called). Make sure to triple check the middle front rear spring bolt to rear frame spring hole, I had to mess with mine (cheat) to get it right.
  3. Lonesomeloser
    15
    Apr 10, 2019
    Middletown, MD
    Yeah, these are already welded in place. Just figured it wouldn't hurt to add a few more plug welds to what is on there from Taiwan. I have the end of the frame rails cut off so I can fit it in position. I will make sure it's square from the rear leaf spring mount hole in the rear frame, and the proper distance. I will also bolt in the front subframe to make sure it's all lined up.
  4. Lonesomeloser
    15
    Apr 10, 2019
    Middletown, MD
    OK. Got some used brackets off e-bay. Why doesn't it seem to be lining up?
  5. Lonesomeloser
    15
    Apr 10, 2019
    Middletown, MD
    I'm thinking I have incorrect brackets.
