New Member ; 80'Z28 "restomod"
Sebambam
12
I'm doing a 76 now (6.0) and went with Holley mounts. They worked out great, long tube headers went in super easy... I don't think the truck intake will fit but that might be a bad assumption on my part. For sure you will want to swap out the oil pan.
thanks i found a cool lil Youtube "guide"
thsi guy usese a lot of parts i thought about using, mounts etc.
question to the fuel system
will a EXTERNAL Bosch 044 (380LH) create enough lift to get the gas up the OEM pickup tube?
Jan 15, 2018
82
Orchard Park NY
Ha, that's the main reason I went with an aftermarket (Holley) intake, because to the tuck one was ugly! lol
I went with an OEM replacement tank and Holley's fuel hanger pump. So I cant help you with your Bosch question.
73Z L92
473
Carlos, MN
On a couple of my LS swaps I used the Bosch 044 pump. They worked well. No failures. For a return line I drilled a hole in the sender and brazed in a short piece of tubing. I use the C5 FFR.
On my 80 project I bought a Tank's Inc tank with a 255 Walbro. Rumor has it the Tank's tanks are out there a ways delivery wise.
Sebambam
12
Where dud you mount them? Can they lift out of the pickup without issues?
I'm not worried about pushing fuel to the front it's more about getting it up into the pump
75Maro
718
Dallas,Tx
I used a tank from ricks that was set up to receive the gen 5 camaro pump. Ordered the pump from vetteworks motor sports. Works great
Sebambam
12
im not to concerned about the look.
further there is a chaep aftermarket Truck intake replacement with the same oem dimensions that i used on previous LS builds that i like since it basically a copy of the FAST 3 piece design.
you can take it appart and port it it flows better than the TBSS Intake
So if the Truck intake fits , this one fits too .. + you can always trim some notches off
Sebambam
12
I mounted the 044 to a bracket I made that mounted to the two tank strap hanger brackets. Mounted the C5 FFR right next to 044. Sorry no pics.
Main thing I want to know if mounted it obove or below the tank level or same level
