New noise... Squeaking
Discussion in 'Engine Topic' started by Twisted_Metal, Sep 12, 2021.
  1. Bandit723
    Bandit723 Veteran Member
    3,677
    679
    Oct 1, 2016
    Waupaca WI
    Dude your spell check is broken.
  2. MChamp
    MChamp Veteran Member
    221
    60
    Jun 6, 2021
    north carolina
    I tried to find an actual material sheet on both but couldn't. My guess is in the impellers angle being slightly different, maybe. It's kinda a catch-22 I think with more flow there's less contact time within the radiator to actually cool the fluid, whereas heavy duty would imply stouter bearing and such. When you think of dead-heading against a closed thermostat (valve) I'd prefer heavy duty. When you start going high velocities the possibility of cavitiation comes into play and will ruin the impeller. I retired from a waterplant, we had pumps capable of 14MGD, it'll sound like it's sucking bb's until all h8ll breaks loose.
    best thing I found so far.
    https://www.vehiclemaintenanceandrepairs.com/gmb-water-pumps-review/
  3. sandlapper
    sandlapper Veteran Member
    794
    291
    Oct 9, 2020
    SE CSA
    rather reliable, very old diagnostic tip ...
    while it's squeaking ... Selectively dribble a little water or beer or whatever on belt-pulley ... if squeaking stops or diminishes, you've found your culprit(s).
    Jodi, wiseryder and MChamp like this.
  4. MChamp
    221
    60
    Jun 6, 2021
    north carolina
    Ha! I'm so gonna go try that on my tractor for kicks.
  5. Twisted_Metal
    29,962
    2,715
    I have belt dressing for that. ;)
    When it had no effect I started to suspect something other than a belt.
    I didn’t even try the belt dressing until after I swapped the alternator belt. :crazy:
  6. MChamp
    221
    60
    Jun 6, 2021
    north carolina
    haha, where's my kewpi doll lol!
  7. 1980RS
    1980RS Veteran Member
    5,516
    1,815
    Jun 17, 2006
    MN
  8. Jodi
    Jodi Veteran Member
    876
    599
    May 22, 2019
    Yep, works like a charm.
  9. Twisted_Metal
    29,962
    2,715
    The new water pump is in.
    All new belts this year too.
    The old pump was definitely junk.
    A little slop in the bearing(s) and it did not spin smoothly.
    (It dragged every 45* of rotation.)
    The fan/clutch is perfectly tight with no wiggle now.
    I got the pump at AutoZone because the old one had a lifetime warranty and it lasted 13 years.
    It came with gaskets and was painted black.
    I masked and painted it before installation.
    (I like the contrast of silver parts against a black engine.)
    Old vs new…
    The old gaskets didn’t want to scrape off the engine so I used a wire wheel on a drill.
    That worked VERY well.
    So clean and shiny…
    The silver paint reflects the red underside of the hood.
    No broken or lost hardware and I only dribbled a little antifreeze on the floor.
    It should be ready for the last car shows of the season now. :D
    Coadster32, MChamp, 70-camaro and 2 others like this.
  10. mallard
    mallard Veteran Member
    1,290
    393
    Oct 3, 2013
    SK, Canada
    I remember some of those gasket issues in spots on some cars so awkward that I couldn’t get anything more than a razor blade in there to “slice” the old gasket material off. :eek:
