1973CamaroLT
I purchased a new 8 qt oil pan, the current one is banged up and there is an oil leak so I will be replacing it in the new week or two.
This pan required a high volume pick up so I assume I need a high volume oil pickup correct? I have heard bad and good about high volume oil pickup, the bad being it slings all the oil to the top of the motor more than on on the bottom which may cause issues with the bottom end?
Specs for oil pan is:
7" deep, 6 trap doors, 2 runners, and 3 crank scrapers. Sump is 14" wide (has dual kick-outs) and 12" long. The stock starter will fit.
I have no idea yet what kind of oil pickup is on the Camaro but I want to buy one before we change this out.
I can't use a high volume pickup on a stock oil pump correct? A high volume pump is needed for the added size of this pan correct?
Thanks
Thanks
