New Right Stuff Rear Brake Kit AFXRD07
Discussion in 'Project Progress' started by czizza, Dec 25, 2014.
  1. czizza
    czizza Veteran Member
    1,131
    118
    Jan 8, 2004
    N. Massapequa, NY, USA
    I believe the kit I bought is not compatible with C-clip eliminators. In the instructions, I believe there is a note about them.
  2. giggity
    giggity Veteran Member
    1,612
    407
    Mar 18, 2013
    Pearland, texas
    I called Right stuff, and they recommended this kit. RSD-AFXRD185
    They said it comes with the correct breackets for C-clip eliminators, however the description online has NOTHING, and I ordered through summit, and summits description had NOTHING...so hopefully its correct....or they allow me to return it.
  3. B.M.
    B.M. Veteran Member
    903
    Jan 11, 2010
    Columbus,Ohio
    I know this is a really old post,but do you remember on your master,if it is a deep or shallow pocket?Just curious because i just got the disc swap for the rear,and looking at master cylinders now,and i see some that say their deep pocket and some say shallow,so just wondering which i need and if i need the short shaft adapter on the shallow pocket master.
    Thanks
  4. czizza
    1,131
    118
    Jan 8, 2004
    I believe deep but I had an adapter to put in the shaft to block or bring up the pocket to make it less shallow. Find the post after the one with the master cylinders and you can see the adapter.
    B.M. likes this.
