New rotors/ what are these?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by volsfan, Oct 12, 2009.
  1. 79T/Aman
    2,626
    236
    Oct 7, 2004
    Dickson TN.
    jee wiz I can't believe the freak out!! would you rather they not be balanced so you don't have to see those weights?
    I understant I'm going to catch hell here for offending but it bugs me when manufacturing procedures are pointed out to be questionable or wrong.
  2. noobwrench
    noobwrench Veteran Member
    465
    Mar 11, 2009
    Lodi/Burson California
    Ive seen a numbers El Camino with those. Its a common thing.
  3. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    Uh no, try again. I have bosch OEM rotors and they have mill fly cuts where they were balanced. Just about no rotor, regardless of manufacturing and metallurgy, will ever balance without adding or removing weight somehow. Some of the methods of removing weight (milled flats or drilled hubs) are less obvious though.
  4. 78Z28rocker
    78Z28rocker Member
    34
    May 8, 2006
    Auburn,AL
    They are for balancing. I have seen them on stock Chevy rotors.
  5. volsfan
    volsfan Veteran Member Gold Member
    2,555
    Jan 4, 2008
    daytona beach, fl
    No offense taken...at least not by me! I was just curious what they were because I had no clue. Since it seems these are common I will go ahead and use these rotors. This board is a wealth of knowledge and I try to tap into that knowledge every chance I get. Thanks to all for the replies.
  6. 79T/Aman
    2,626
    236
    Oct 7, 2004
    Dickson TN.
    No problem, sorry not trying to offend, most often than not things are done for a reason, yes some methods are less expensive than others but this is to meet customer price points.
