New Shop!
Discussion in 'The BS Topic' started by ChevyReb, Mar 10, 2017.
  1. 70-camaro
    70-camaro Veteran Member
    3,417
    1,827
    Mar 25, 2010
    marietta ohio
    You will want a tool room with plenty of room for jacks, Jack stands, dolly's, welder, engine stand and hoist, and so on, maybe spare parts. You get the picture. A 10 x 6 room will fill up fast even with shelves.
  2. ssupercoolss
    ssupercoolss Veteran Member
    987
    332
    Nov 3, 2015
    PA
    Its kind of a shame the builder wont cut holes in the roof. We installed some type of big bubble skylight thingys at our shop. 5 or 6 of them. looking up at them they just kind of look opaque, but they are supposed to amplify the light coming in. We can shut the lights off in the shop during the day with little difference in light. It helps a ton in the summer with the heat in the shop. Happy mechanics. We also put in some solar vent fans. these really help too.
    think about some ventilation.
  3. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I would rather have a solid ceiling with 2-3 feet of insulation then a sky light.
    LED lights are dirt cheap to run, heat is expensive!!!
    Trust me, I've had a 3000' shop for 23 years, heat is the biggest cost by far.
    Of course, I'm the dummy that works in a t-shirt, instead of turning it down and leaving a coat on.
  4. ssupercoolss
    987
    332
    Nov 3, 2015
    PA
    ^^^ we heat our main shop with waste oil, so our heating bill is pretty low.
  5. ChevyReb
    4,331
    213
    Feb 4, 2003
    SC
    Well down south here it's hot more times than cold, so I'm hoping that the high ceilings are going to help keep it cooler. It would be nice to find a deal on one of those Big A$$ Fans, That's another reason I put the other garage door in the back to be able to pull air through in the summer. Heck it was in the 80's here for a week strait in February!! Probably see some more Florida retirees moving this way...we call them half-backers HAHA. I will wait until I see how it turns out inside before I add any other rooms in the shop area. It will not be easy to heat that big of a space! I'll probably put in a porcelain wood stove and see how that works. If it's too hot or cold I'll get the spray in insulation and seal it up. I need to check and see how much extra it is for insulated garage doors.
  6. Shizzle
    Shizzle Veteran Member
    2,801
    777
    Aug 1, 2012
    oak lawn, illinois
    You can insulate the garage doors yourself with 1.5" foam.
    An option I'd recommend over drywall is 1/2" OSB or plywood. You don't have to worry about hitting a stud to hang a shelf, bracket, etc.
    They are close to the same price as well.
  7. 70-camaro
    3,417
    1,827
    Mar 25, 2010
    marietta ohio
    And you can paint the plywood white to brighten the room. I burnt wood for several years and finally bought a wood pellet stove. Very good heat and a lot less mess and work than fire wood. Also a 52 inch industrial ceiling fan.
  8. mrdragster1970
    7,821
    507
    Apr 12, 2007
    I also have central air, but my shop is very well insulated, well worth running the air when it sunny & warm out.
    I even sealed the over lap of the steel sheets just to help drafts.
    It's still hot as frick on the deck if I don't run the fans.
    I have gravel parking lot, so I keep the doors shut as much as possible, so no breeze to help.
  9. BowHunter
    BowHunter Veteran Member Lifetime Gold Member
    963
    17
    Nov 12, 2004
    Wappapello Mo, USA
    NOT BIG ENOUGH !! Especially with living quarters in it!
  10. budro6968
    budro6968 Veteran Member
    3,920
    747
    Apr 2, 2016
    Jax Florida
    Is there a toilet? Nothing like a private place to do your business. I guy I know did a secret septic system and hid the sewer drain under a coffee can lid when the concrete was poured. When the final inspection was done he busted through the thin layer of concrete and hooked up his toilet.
