New Shop!
Discussion in 'The BS Topic' started by ChevyReb, Mar 10, 2017.
  1. 80sz
    80sz Veteran Member
    3,878
    727
    Feb 2, 2014
    Buffalo,n.y.
    Shaking my head in amazement . What's next Cuz you got sweet glass block you need gorrila bars now and shatter proff glass in front for everyone's protection? Like I say at work why don't ya just wrap me in styrofoam then I'll go to work.
  2. 71 rs BBC
    71 rs BBC Veteran Member
    477
    65
    Nov 28, 2016
    Indy
    Big gable fans are awesome! Cool it right down. I went 4 or 5 years before I got mine. I put drains in every bay and in the work areas also. I have a bathroom with stand up shower for when I get really nasty and keeps the wife happy. I tiled the whole thing also. Cleanup is with a hose. Lol.
  3. mrdragster1970
    7,821
    507
    Apr 12, 2007
    Just finished my new 23 x 16 deck, came out decent.
    The guys helping were not that swift, but it's done!!!!
  4. ChevyReb
    4,331
    213
    Feb 4, 2003
    SC
    Making some progress. Having a hard time getting a plumber! I'm about to youtube it and put stuff in myself. They put concrete forms on today so waiting on me! :-(
    Front view
    Side
    Rear - Went with the bigger 10x9 door in the back, about same price so what the heck.
    Dave Nelson likes this.
  5. Bandit723
    Bandit723 Veteran Member
    3,562
    641
    Oct 1, 2016
    Waupaca WI
    Looking really good so far....I bet you will appreciate this once it is done.
  6. CamarosRus
    CamarosRus Veteran Member
    8,546
    148
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Install Floor drains .......................floor trench...........slope floor toward center trench....
    Install gravel and visqueen moisture barrier.......
    Install heavy wire mesh to make floor stronger
    Cut grooves in concrete in 10' grid pattern
    STUDY www.garagejounal.com FLOORS forum
  7. ChevyReb
    4,331
    213
    Feb 4, 2003
    SC
    Thanks Chuck but you mis-spelled link. Ill have a look over there. http://www.garagejournal.com/
    They are putting in 6 mil vapor barrier and concrete with fiberglass in it. These guys use a steel channel like __|----|__| but vertical for the seems to keep it from cracking.
    I may ask about drains but not certain I want to do that.
    I need to find out how far apart to space for two post lift to add some footers for that.
  8. CamarosRus
    8,546
    148
    Feb 16, 2000
    I have a ROTARY 9000# Two Post Lift installed in my shop......Floor is too thin
    at 4" (????) (I bought house with shop...I had no control) Most of my anchor
    studs torqued to the 100+lb spec but a few didnt bite good and are pulled UP
    some.....I heard about using a high spec all thread and epoxy gluing studs
    into concrete ......
  9. Bandit723
    3,562
    641
    Oct 1, 2016
    Waupaca WI
    Installed a lift in my garage. Had the same issue with a few or at least the one side of the lift having issues with the wedge anchors pulling up. Pretty sure it was due to the quality of holes i did on that side of the lift. both sides were i anchored into the floor had 4" of concrete.
    From what i have read you may want to do a bit thicker pour and a higher psi concrete if you know where a lift will go. I did fix my problem by using some epoxy anchors from wej-it and applying the inject-tite awf epoxy.
  10. Green hornet
    Green hornet Veteran Member
    2,021
    470
    Oct 11, 2015
    North Bay, CA
    That is going to be one great space. I was cleaning up my garage this weekend. I've go 10 pounds of poo stuffed in a 5 pound garage. I'm so jealous, enjoy.
