New Summit wheels just arrived (Drag-Thrust)
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by BeefTip, May 9, 2013.
  1. BeefTip
    BeefTip Veteran Member
    722
    Aug 11, 2007
    Phenix City, AL
    Skip Im actually going go try to weigh them this afternoon, my grandfather has a commercial scale that is pretty accurate so I will take them over later.
    Also, here is a pic of the 15x8 and 15x10.
  2. Skip Fix
    Skip Fix Veteran Member
    2,209
    24
    Mar 21, 2007
    Katy,Texas
    I know my cast 15" snowflakes are around 23-24#. 16x8 GTA mesh around 22 for the repops, the originals look a little lighter.
    My Pro Stars are way lighter.
  3. 5spd540
    12,388
    16
    Sep 19, 2009
    Guyton, GA
    Those dont look like they hace the correct offset it may just be the pics
  4. Z28zz383
    Z28zz383 Veteran Member
    814
    11
    May 11, 2012
    Florida
    Very nice looking wheels. What center caps are you using?
  5. 973800CamaroRs
    973800CamaroRs Veteran Member
    702
    Nov 27, 2011
    Frederick Maryland
    Those are nice :bowtie: Cant wait to see them with tires.
  6. BeefTip
    722
    Aug 11, 2007
    Phenix City, AL
    Backspacing is supposed to be 4.4 and 5.5 respectively, I will check later. They do however look correct to me from what i have seen of these wheels online.
    Btw, I just weighed the wheels and the are not exactly lightweights.
    15x10 came in at roughly 19.5 lbs
    15x8 was just over 18 lbs
  7. BeefTip
    722
    Aug 11, 2007
    Phenix City, AL
    The wheels come with center caps and km just going to use those. I'll post a pic of them later
  8. BeefTip
    722
    Aug 11, 2007
    Phenix City, AL
    I just checked the backspacing and it is in fact correct. The 15x10 are 5.5 and the 15x8 are 4.5.
    However, I do see what you are talking about, it seems that both wheels should be set deeper toward the center of the wheel. I had noticed this on other summit wheels, especially the fast-fives, they just do not sit that deep. The way these wheels are cast, the mounting plate sits almost another inch deeper than the backside of the face of the wheel, which makes it closer to center (hence the illusion of these not being deep enough). Basically it makes the 15x10s look like they are closer to a 6.5" backspace visually.
  9. BeefTip
    722
    Aug 11, 2007
    Phenix City, AL
    Tires just came in.... I will be running m/t radials 235/60 in the front and these monsters in the back..Mickey Thompson S/R 28x12. Im waiting to get my car back within the next week or two, then I will test fit the new wheels before I mount the tires.
  10. patpkk
    patpkk Veteran Member
    185
    Jul 21, 2008
    Do these rims have a conical seat for the wheel nut. It appears that they may.
    If so do you have stock wheel studs?
    How much thread engaement do you have?
