New Sun Visors Install Help
Discussion in 'Interior Restoration' started by RickM, Aug 1, 2020.
  1. RickM
    RickM Veteran Member
    516
    83
    Apr 16, 2004
    Gaithersburg, MD
    OK I have purchased new sun visors for the 81 Camaro.
    Am I supposed to peirce the vinyl so that the bracket pin can slide into the visor channel?
    There is no pre-punched hole in the new visor. How the heck do you get the bracket into the channel without punching a hole into the new visor.
    I shouldn't be this hard. What am I missing?
    Help
    RickM
  2. Twisted_Metal
    27,813
    1,360
    Pics?
    There should be a hole in the end for the bracket rod AND a hole for the retaining screw.
  3. RickM
    516
    83
    Apr 16, 2004
    Gaithersburg, MD
    WP_20200801_19_03_38_Pro.jpg WP_20200801_19_03_13_Pro.jpg Here are some pics. No hole for the bracket pin
  4. Twisted_Metal
    27,813
    1,360
    Yup... You’re going to have to poke a hole in it.
    Remove the screw before you push the bracket rod inside.
    IIRC... The screw fits into a notch on the rod.
  5. 74Z28GC3
    74Z28GC3 Veteran Member
    1,754
    66
    Sep 1, 2000
    North Pole, Alaska
    This Fbodywarehouse link should help you.
  6. RickM
    516
    83
    Apr 16, 2004
    Gaithersburg, MD
    Well I emailed Acme Auto Headlining about this and got this reply:
    Hello,
    The visors are made that way. All you need to do is take an ice pick or something sharp and put a small hole where the bracket pin is inserted. You can feel the opening through the vinyl using your finger. A small hole is all that is needed. What part number did you buy?
    Thank you and best regards,
    Stephen Delman
    Acme Auto Headlining Co.
    550 West 16th Street
    Long Beach, CA 90813
    800/288-6078, Ext. 215
    So for anyone who buys new sun visors, here is the answer.
    RickM (Still serving time in paint jail):mad:
  7. COPO
    19,091
    1,367
    The video failed to show poking a hole for the shaft. If I made the video I would have mentioned that “here is where you’ll need to make a hole and you do it like this”. Then I would have shown the shaft install and how it’s locked. Simple but a fail in this video.
    74Z28GC3 likes this.
  8. RickM
    516
    83
    Apr 16, 2004
    Gaithersburg, MD
    Agreed
  9. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,831
    95
    Jul 31, 2001
    Ft. Lauderdale, FL
    I just put a new set on, You do need to put a hole or slice there, and mine pushed onto the pins super...super hard.
    No matter how you may be tempted, don't put any WD 40 or lube in there to make them slide on easier
