nitrous/carb single fuel pump
Discussion in 'Competition Camaros' started by 89rodknocker, Jul 30, 2014.
  1. 89rodknocker
    89rodknocker Veteran Member
    607
    Apr 10, 2008
    Fremont, Ca.
    Im plan on running a single cheater plate max 200 shot. I have a a2000 pump and a mallory140. I was wondering if either one of those pumps would be good enough to run both the carb and plate off of one. I dont have the funds to sump the tank right now but want to run at the next grudge with the plate on.
  2. J78
    J78 New Member
    24
    Nov 3, 2003
    LOUISVILLE, KY
    I have run C 140 feeding the motor with a 175 shot, and it kept up through the 1/8 no problems. If you already have both pumps it would be cheap insurance.
  3. 79CamaroZ28
    79CamaroZ28 Veteran Member
    1,243
    Aug 1, 2001
    tucson, Arizona
    I would run dedicated fuel system.. neither of those pumps are up to the task...
  4. CorkyE
    11,428
    932
  5. LeKid
    LeKid Veteran Member
    437
    8
    Feb 5, 2006
    Winnipeg, MB
    The A2000 is MORE then enough for your setup. I know some Top Sportsman guys runnign 1200hp on motor and 800hp of nitrous with this pump with no issues.
    I have an Holley 350gph that feeds both my motor and nitrous and I make aroung 1000-1050hp total.
    Running a single pump is way easier and better IMO.
    I did the 2 pump deal years ago and it was more trouble then anything. Wouldn't do it again. If the nitrous pump does not turn on or dies, you melt the motor. If you only have one pump and it dies, the car stalls and nothing gets broken, way better!!!
  6. runudown72
    runudown72 New Member
    26
    Feb 18, 2009
    Flint, Michigan
    What is the engine combo? I don't think I'd trust running any kit and carb through a single stock line. just my opinion.
  7. LeKid
    437
    8
    Feb 5, 2006
    Winnipeg, MB
    I am not using the stock line. I have a -12an from the tank (tank has a sump) to the pump (Holley 350gph) with a -8an bypass back to the tank from the pump, then -10an from the pump to the fuel log where I have 2 regulators, one for the motor and one for the nitrous. I run a 665hp 400ci sbc with 300hp of nitrous. It is making 1000-1050 on nitrous at the crank.
    You can't use the 3/8" stock line for anything more then around 500-550hp, max!!! Installing a ssecond pump would require another line to be passes, so might as well do it properly the first time.
