No spark
Discussion in 'Troubleshooting & Diagnosis' started by Layne02, Jun 29, 2019.
  1. Gary S
    23,992
    1,548
    Cars with HEI no longer used the wire from the starter to power the ignition during cranking. That was something needed only on points ignitions to bypass the resistor wire. The HEI gets full power directly from the ignition switch in both "start" and "run". If the new harness is wired exactly like the original, and the power isn't going to the HEI during "start", it appears that the ignition switch is defective.
    The wiring diagrams show the pink wire to the HEI should be powered during both "start" and "run".
    jeff swisher likes this.
  2. Layne02
    Layne02 Veteran Member
    139
    Jun 25, 2013
    Georgia
    Well alrighty, I swapped ignition switch for an old one. That fixed the loss of voltage in start position. Now the thing still doesn't start, so thinking timing may be off . At least I have one problem fixed, on to the next one.
  3. Gary S
    23,992
    1,548
    Good! Now you move on to another problem. Not what you wanted, but at least you can consider it progress.
  4. Layne02
    139
    Jun 25, 2013
    Georgia
    This car has gone fairly smooth so far, guess I was due a problem or two.
  5. Layne02
    139
    Jun 25, 2013
    Georgia
    Forgot to say thanks for all the info!
