Not safe to have 4 speed with T-tops?
Discussion in 'Camaro Questions' started by prosuperstar5, May 12, 2010.
  1. prosuperstar5
    prosuperstar5 Veteran Member
    292
    Apr 2, 2010
    Savannah Georgia
    I've talked to a could of people about wanting to put a 4 speed in my 1980 camaro with t tops which is an automatic now and they strongly suggest I dont because I will crack my t tops and twist the body. Has anyone ever hear such things or is it just bullshit?
  2. andrew1977
    andrew1977 Veteran Member
    1,499
    Oct 1, 2006
    parksvegas, BC
    it is true. the roof on the 78-81z28 4spd t-top cars do crack in diffrent places. the windshields also tend to break... mine broke because of flex, and a guy i used to work with had it happen
    sub frame connectors, and poor traction are a must haha,
  3. Marks71BB
    11,834
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    Due to the uni-body design of the second gen it is prone to body flex and thus cracking when a fair amount of power is added to good traction.
    being an automatic or four speed has little to do with it.
  4. andrew1977
    1,499
    Oct 1, 2006
    parksvegas, BC
    well...if your running big power yes it doesnt matter if itsa 4 gear or an auto. but stock or mild, 4 gear vs auto. the standard trans is way harder on the car.
  5. prosuperstar5
    292
    Apr 2, 2010
    Savannah Georgia
    so what do people do to t topped 2nd gens to get them to handle maybe 500+ horsepower?
  6. 79camaro2001
    4,783
    May 4, 2003
    Monroeville, PA
    BAM!
    what he said is true.
  7. 79camaro2001
    4,783
    May 4, 2003
    Monroeville, PA
    Well for started you need to reinforce the frame. You can do this by subframe connectors, roll cage, getting rid of the T-Top by going with solid roof(but this is marginal at best), and I've seen braces that connects to the firewall to the front sub-frame.
  8. andrew1977
    1,499
    Oct 1, 2006
    parksvegas, BC
    a member here runs 10s with t-tops. he has an 8 point cage, and sub frame connectors. his is an auto. but its comparable because you won't get close to tens with 500.
  9. andrew1977
    1,499
    Oct 1, 2006
    parksvegas, BC
    btw. here is a pic of one of our street/strip cars. 400hp lower 12s.
    bone stock driveline, flywheel, clutch, trans, d-shaft, diff has cheap 373's. try launching that hard with a stock auto... harder launch= parts beak, chassis flex.
  10. prosuperstar5
    292
    Apr 2, 2010
    Savannah Georgia
    best place to buy sub frame connectors?
