NPD dash 70 camaro, 2 Screws screws above gauges. What are you guys using?
Discussion in 'Interior Restoration' started by 1970Camaro, Dec 10, 2020.
  1. bondora68
    bondora68 Veteran Member
    403
    122
    Dec 14, 2014
    Mobile, AL
    I will get a picture of it tonight.
  2. badazz81z28
    20,733
    1,418
    Alabama
    If you have a 70-78 NPD dash, there are no tub grommets....they failed to get those in the dash when they designed it. You will need an alternative. I glued thin piece of Sheetmetal to the dash for screws to bite into
  3. bondora68
    403
    122
    Dec 14, 2014
    Mobile, AL
    Here are mine...empty holes...
    Looks like I am also missing the clips that go into the metal dash that hold these screws....
  4. bondora68
    403
    122
    Dec 14, 2014
    Mobile, AL
    Where did you glue the pieces? On the dash pad? Or on the metal dash?
  5. badazz81z28
    20,733
    1,418
    Alabama
    On the dash pad where the grommets are supposed to be. I scuffed the area and used a 2-part epoxy.
  6. bondora68
    403
    122
    Dec 14, 2014
    Mobile, AL
    Did you put them in the inner layer? Or can they be seen above the steering wheel?
  7. GoldenOne7710
    5,556
    835
    Jun 23, 2004
    Athens, GA
    Is that an oval shaped hole?
  8. bondora68
    403
    122
    Dec 14, 2014
    Mobile, AL
    No, it's a metal insert or plate but there is no hole...
  9. bondora68
    403
    122
    Dec 14, 2014
    Mobile, AL
    Did you epoxy that metal here above the red circle? (See pic below)?
  10. boardog
    boardog Veteran Member
    962
    20
    Dec 8, 2006
    north ga
    mount the dash in the position you want it to be. use you hand and push the dash tight up against the metal body structure and then take a marking pen or something to mark the screw holes. remove the dash and drill the holes with a very small and tiny drill bit. you can use the oem screws to mount the dash. the hard plastic tabs in the npd dash will work just fine. just don't use a socket or a ton of force to tighten them.
    bondora68 likes this.
