OD transmission
Discussion in 'Transmission & Driveline Topics' started by Strange81Z, Jun 4, 2021.
  1. Strange81Z
    Strange81Z Veteran Member Lifetime Gold Member
    5,992
    20
    Nov 29, 2001
    Amarillo, Tx
    Which OD transmission will work with Botha SBC and a BBC? I want to go with a SBC at first but later upgrade a BBC.
  2. Twisted_Metal
    29,685
    2,525
    Any OD transmission will fit.
    But it needs to have internals which will hold up to the torque of a big block and it’s intended use.
    Big tires on a sticky track (racing) will require more upgrades to the internals than something driven mildly on the street.
  3. Strange81Z
    5,992
    20
    Nov 29, 2001
    Amarillo, Tx
    Oh its just going to be a street car. Maybe a test a tune night or two. Nothing major.
  4. camaro71/holland
    1,494
    196
    Aug 27, 2003
    The Netherlands
    As stated by Twisted, only difference will be the amount of money to make it work.
    200-4r cores are harder to find than 700-r4's. Both types were never put behind a BBC for a reason and will take knowledge and $ to make it work especially regarding the internal parts with the 700 on the cheaper side.
    But...a 200-4r might save you the costs of changing the length of the drive shaft.
    A 4l80e will probably be strong enough in stock condition, but will require an investment in the driveshaft and a stand alone computer. If you need or decide to upgrade the TQ, these ain't cheap either.
    So without knowing the needs of the total combination I would say, from cheapest to most expensive: 700 > 200 > 4l80. With the latest having most potential and least maintenance in the long run.
    Strange81Z likes this.
  5. Strange81Z
    5,992
    20
    Nov 29, 2001
    Amarillo, Tx
    Awesome. What would I expect to pay for a 700 or 200 to beef up and the parts to retrofit?
  6. Fbird
    5,605
    1,549
    Feb 12, 2011
    atlanta, ga
    a 200 will take every pc of hardened, upgraded internals out there, 300m internal shafts etc AND somebody who knows how to make one WORK with a TORQUE motor AND traction. There are several folks capable .... just depends on your usage. Traction breaks stuff!!! For a 200 behind a mild BBC you can expect to have one built around $4,000 + a convertor
  7. Twisted_Metal
    29,685
    2,525
    ^ +1
    Exactly.
    It's not cheap to build an old OD transmission to handle the grunt of a big block, if you're not just spinning tires.
    Spend the money and build it right if you plan any sticky track & big tire launches.
    It only takes one run to break stuff and turn your "Test-n-Tune" event into an expensive "Test-n-Tow" day. :(
  8. 77 cruiser
    77 cruiser Veteran Member
    587
    36
    Nov 17, 2006
    Frostbite Falls MN
    So far I haven't broke my 200, I'm at 540 tq. in a 4200 lb. Monte. It only has a billet shaft forward drum.
    Peck likes this.
