OER fuel sender
Discussion in 'Electrical Systems' started by 73RATTYZ28, May 1, 2020.
  1. 73RATTYZ28
    73RATTYZ28 Veteran Member
    516
    36
    Feb 23, 2001
    White Plains NY USA
    I have read mostly bad things on the board but is anyone using one who is happy with it? I bought one if I test it with an ohm meter and it’s in range is it worth Installing? I don’t want to do it again. The original still works but the tank is leaking when full.
  2. Jim Streib
    404
    67
    Apr 6, 2004
    Saint Louis, MO USA
    I have to wonder if it's the O-ring that is leaking.
    Heck if the old one is working, drop the tank, figure out the leak and if it is the O-ring, replace it and then check how well the ground wire it attached to the sender as well as the other connections.
    Also while you are under there see how well the rubber lines are that are attached to the steel lines.
    Jim
  3. bodymanbill
    bodymanbill Veteran Member
    1,592
    1,184
    Feb 1, 2007
    South Park Pa
    I just replaced my original one with one from NAPA with no issues, took them a couple days to get it though.
  4. 73RATTYZ28
    516
    36
    Feb 23, 2001
    White Plains NY USA
    Just dropped my tank. The factory sender has two lines coming out of it but the replacement only has one. Is one a return and do I need it?
  5. 73RATTYZ28
    516
    36
    Feb 23, 2001
    White Plains NY USA
    I’m done with oer the ground cable on the sender isn’t long enough to reach the ground the tanks installed but the fill tube is too high in the body to get the cap on. Anyone have this problem f OER
  6. 73RATTYZ28
    516
    36
    Feb 23, 2001
    White Plains NY USA
    Bent the filler so it’s acceptable but now the stock gas cap doesn’t fit the new tank
