Oer junk ! Upper door hinge suggestions 70-73 firebird
Discussion in 'Body Restoration' started by 72BIGBLOCK, Sep 24, 2020.
  1. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,829
    258
    Feb 2, 2008
    SF
    image.jpg 9954AD26-68C1-43F0-84F4-974BBC150D88.jpeg I bought some oer upper hinges because I didn’t want to deal with the spring on the upper hinge and low and behold not even a year old with very very limited use they are starting to come apart ?! The part where there is a spinning bearing is bending every time I open or close the door, it’s gonna snap soon so I need some suggestions
    Are oer parts that low quality now ?
    Should I look for some used hinges and have them rebuild ?
    Not even a year since replaced on a car that doesn’t move because ive been working on the tunnel to install a 6l80 and has no drive shaft
  2. Twisted_Metal
    29,962
    2,715
    The roller looks to be in bad shape already too.
    You might be able to replace the pin and roller with a better quality piece than OER uses.
    4th gen Camaro parts... Slightly different but they work.
    Check this thread --> https://nastyz28.com/threads/cheaper-door-hinge-detent-roller-solution.186475/
    Parts are available on ebay if your dealer doesn't have them.
    https://www.ebay.com/itm/GM-OEM-Loc...374618?hash=item5d8c37055a:g:A-YAAOSwTf9ZQ2Tg
    https://www.ebay.com/itm/GM-LOWER-D...518320?hash=item3d55cd3ab0:g:3LAAAOSw0YlZdFPO
    Double R Restorations likes this.
  3. 72BIGBLOCK
    2,829
    258
    Feb 2, 2008
    SF
    Those are new :( I put them in about 6 months ago and rarely even open the doors since I didn’t need to
  4. Double R Restorations
    2,554
    34
    Jan 11, 2002
    That thread that Terry linked to is what I used to rebuild mine. The 4th gen roller is a little wider but worked great.
  5. 72BIGBLOCK
    2,829
    258
    Feb 2, 2008
    SF
    Update ! Classics stepped up and actually replaced them so big shout out to classic industries!! I do hope they last longer than six months this time
    Zstar and GoldenOne7710 like this.
  6. GoldenOne7710
    5,583
    854
    Jun 23, 2004
    Athens, GA
    I bought a set of aftermarket hinges...probably 15 years ago. They weren't OER pieces and I'm not sure what 'brand' they were. I bought them from classicmuscle.com (also used the name Modern Chevrolet back then). They're made better than the GM hinges I took off the car in a side by side visual comparison.
    Now I'm curious about who made them. I'll have to dig through all my invoices from back then to see if I can determine it.
  7. giggity
    giggity Veteran Member
    1,608
    405
    Mar 18, 2013
    Pearland, texas
    rebuilding OEM hinges is pretty easy, if you still have them and you have issues with these aftermarket hinges, Id say rebuild your factory ones.
  8. Zstar
    Zstar Veteran Member
    2,617
    892
    Mar 23, 2014
    Ocala, Florida
    If those go bad, Dynacorn has excellent hinges.
