Oil Pressure Sensor
Discussion in 'Electrical Systems' started by Coadster32, Aug 18, 2020.
  1. Coadster32
    1,956
    237
    Oct 2, 2013
    Milford,CT
    Hhmm...I'll take a look there as well. Maybe someone can post up a pic of that plug being used?
  2. flht99b
    flht99b Veteran Member Gold Member
    699
    214
    Nov 28, 2014
    Knoxville, TN
    I have Daniels oil pressure gauge and the OEM idiot light in my car. The oil galley behind the distributor I have a T and a 90 elbow on each end of the T with the OEM sender and the large oil pressure sender you have, MSD HEI distributor. Have to get the angles right but works fine. Hopefully these pictures help.
    Bills69 likes this.
  3. GoldenOne7710
    5,222
    666
    Jun 23, 2004
    Athens, GA
    That's how mine is. The sending unit for a gauge is a little bulky and takes up more space. I have my gauge sender tapped into the port above the oil filter. Still plenty of room between it and the headers. The switch for the oil light is a lot smaller and doesn't interfere with anything at the port behind the intake on the top of the block. It works great for me.
  4. Coadster32
    1,956
    237
    Oct 2, 2013
    Milford,CT
    Sounds good to me as well. Would you happen to have a pic of this port?
  5. 80sz
    80sz Veteran Member
    3,426
    509
    Feb 2, 2014
    Buffalo,n.y.
    The oil filter ports good , just close to header for routing. Just above filter
  6. GoldenOne7710
    5,222
    666
    Jun 23, 2004
    Athens, GA
    The picture is a little deceiving. The port is a little closer to the back of the block than it appears in the picture. The picture makes it look like it's directly below the exhaust port on cylinder #7....but it's actually far enough back that it's not too close to the header tube. 20200916_155622.jpg 20200916_155634.jpg
    Coadster32 likes this.
  7. Zspoiler
    Zspoiler Veteran Member
    3,693
    336
    May 6, 2012
    Federal Way, Washington
    I run an Autometer mechanical and a low oil pressure light on my small block.Using a some brass an AN fitting near the HEI distributor.
