Olds 403 Second Gear Power Loss
Discussion in 'Troubleshooting & Diagnosis' started by Smiles 79, Aug 17, 2020.
  1. CorkyE
    11,108
    789
    Yes it will.
  2. frank5s
    frank5s Veteran Member
    297
    31
    Sep 6, 2008
    Naperville Il
    The olds fuel pump run off a eccentric on camshaft
  3. mallard
    mallard Veteran Member
    958
    258
    Oct 3, 2013
    SK, Canada
    I read your other post about fuel pump pressure. Although the OP has a new fuel pump on his car I think you're right, he should be checking pump pressure in case that sock is in fact plugged. Forty plus year old car and all....
    Smiles 79 likes this.
  4. berg2695
    berg2695 Veteran Member
    406
    103
    Nov 13, 2011
    AUBURN, WA
    Have someone drive behind you to see if there is visible smoke from an over-rich condition when this problem occurs.
  5. CorkyE
    11,108
    789
    It's not a common problem but the cam or the shaft could be worn. Road Kill had a worn shaft.
    A fuel pressure gauge will certainly be revealing.
  6. INSPECTOR57
    INSPECTOR57 Veteran Member Lifetime Gold Member
    491
    25
    Sep 14, 2007
    Stillwater, Oklahoma 74075
    You say that you've disconnected the charcoal canister & plugged the port at the carb - you didn't cap of the vent line from the canister to the tank did you?
    If the tank is not vented it will cause an issue like you're describing.
    Gary
    frank5s likes this.
  7. RxRmechanic
    RxRmechanic Member
    42
    13
    Jan 17, 2020
    The sock is probably a good place to start if not for anything else then for maintenance sake. It is over 40 years old. It's good to get intimate with your ride. If the bird ever sat for an extended period of time, I'd imagine it'll become apparent once you look inside the tank. Either way, I guess there's only one way to find out. Off the subject... How come you can take a currently 15 year old car, and rubber hoses, etc can still look as good as new in most cases? However, when you dove into ANYTHING from the 70's prior at about the same age (say 10-15 years old) then everything rubber around the tank basically fell apart to dust right in your hands or was petrified? Oh well.. I don't know. Probably just a Mid Atlantic thing. New York like winters and Louisiana like humid summers. Hope you get her straight, I'll lurk to find what you found.
  8. frank5s
    297
    31
    Sep 6, 2008
    Naperville Il
    The olds motor has a part that bolts to the end of camshaft, look like a freeze plug that is out of round,
    the fuel pump lever rides on the freeze plug like eccentric
    https://www.autopartsdb.net/assets/images/ProductImg/T/TA4005.JPG
  9. CorkyE
    11,108
    789
  10. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,799
    531
    Aug 11, 2010
    erie, PA
    vacuum leak on the transmission side...the modulator or something in there
    if it pulls hard in first gear, runs fine in first but Fs up in 2nd the trans has to be causing the issue
